?'s about p0315
?'s about p0315
Did a mail order tune swap. pcm now shows the p0315 code. Is that because of the different pcm or because the code was already set in new pcm.
St. Jude Donor '13-'14-'15
Read this----more than likely a new ECM requires you to do a "Crank position relearn procedure " can be done at any tuner ----
http://www.gearchatter.com/viewtopic11737.php
