C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Anyone using the ebay ELM327 OBD2 USB cables?
Old 05-19-2010, 02:13 AM
Z06Electron
Z06Electron's Avatar
Default Anyone using the ebay ELM327 OBD2 USB cables?
Bought one on ebay, can't get it to connect with the software supplied. Can't be the freaking complicated to communicate with the damn computer. Using Scantool.net software, but big surprise if you don't buy their tool then zero support. Tried it on the Beetle, Denali, and Vert and nada.
Scanner is this one.
http://cgi.ebay.com/Diagnostic-SCANN...item414f8ad9f3
Old 05-21-2010, 10:42 PM
sk7
sk7's Avatar
I'm also using an ELM327 on an older laptop (DB9 connection) and it works good. I found proscan software to be the best (in the freebie dept). Does windows auto install the USB driver or do you have to do it manually. Has to be a port configuration issue.
Old 05-25-2010, 09:03 PM
davydman
davydman's Avatar
i bought it over a year ago works great to read and clear codes.
Old 08-27-2013, 09:11 PM
T_Vert
T_Vert's Avatar
Did you guys get this to display any sensor info? Works on my `13 kia optima but not the 2000 vette.
Dave
To Anyone using the ebay ELM327 OBD2 USB cables?
Quick Reply: Anyone using the ebay ELM327 OBD2 USB cables?
