SD tune or stay with MAF tune for my needs?
So I will be installing an A&A SC system on my 04 coupe. Car's stick, has a stock LS1, 2000 miles on it and will be running factory manifolds. I would like to make low 500rwhp.
The tuner I'm considering using is about three hours away and is suggesting a SD tune. They will charge me the same price either way with about $80 in parts to run the SD tune.
So I live in NE ohio no big elevation changes but the temps to swing alot. We see during the summer 90's during the day and then 60's at night.
Look, my car is a weekend car/garage queen, will se an occasional quarter mile pass in street trim, no drag packs and such. I just need a good solid tune that will not require frequent visits to the tuner since they are 3 hours away.
So for my needs SD or MAF tune?
Thanks for your help,
Darion
Darion
A good speed density tune won't require tweaks because of temp changes. Remember, you'll still have both an engine temp sensor, and IAT. Dodge has never run a MAF, all their stuff is speed density. You think if speed density was so unstable an OE would use it exclusively?
PS, I would HIGHLY recommend headers. Especially with a supercharger. The biggest reason is they will help expedite the removal of combustion temps. You'll be able to run more timing with less chances of knock. much better all the way around for your motor.
Former Vendor
Darion
Darion
Former Vendor
Pretty much what is said above.It can be done both ways. Doing it for the same price scares me because a correct SD tune for boost takes alot longer to get perfect.
Thanks everyone for taking some time to post up on my question. At this point I have an A&A system coming and will do the install at the end of this month. I'm shopping tuners and will make a decision when I feel comfortable with the information I get. I'm not getting hung up on having one tune over the other, just that I get a good tune either way.
Thanks again for the opinions,
Darion
Darion
Exactly what I was thinking. It takes (me at least) at LOT longer to dial in a SD tune. So much so, that some tuners won't even do them
Frankly at this point I am leaning toward a MAF tune because I have a tuner about an hour away and that is what they are most comfortable with. They are LSX experianced and do a bulk of work on LSX motors. I'm going to do the install take it over to them and stand over their shoulder the whole time.
I think once I get past these steps I'm going to get HP Tuner and start to learn what tuning is all about. At least learn the basics and then move up from there. Besides cycling I don't have a ton of hobbies so I think I'll add this.
Thanks again,
Darion
St. Jude Donor '13-'14-'15
The MAF table on the older 3.5" ones maxed out at 11,250 HZ---The newer style 4" ones ( like yours) max out at 12,000HZ
As an example my car (98) is apprx 400 RWHP using the old MAF---My eng will go all the way to 10,000 HZ so I'm ok using a MAF tune just barely--
I tuned a blown 97 with the old MAF that has apprx 430 RWHP---My data logger showed that the MAF values went above 11,250 to 11,500-- So we used a SD tune instead---But on a newer 4" MAF engine with a max of 12,000 it would have been OK--
I would guess that with 500 RWHP on an 04 you'll be over the 12,000 HZ max and a SD tune would work best---
