1515 Reduced Engine Power
Is the ls2 TB a direct replacement for the ls1/6?
Ronnie_W (11-01-2015)
I'll have to try and wrap my head around what you are saying. I'm using EFILive. My C6101 table is maxed out so I'm not exceeding those values. I took my car out again today and logged a couple of pulls. Without activatiing my nitrous switch the car did great. I actvated the nitrous switch (without the bottle turned on), which in turn activates my IAT tricker circuit and it went in to REP around 5800 or so. My IAT tricker ckt puts my IAT at -6 degrees and I have it set up to pull 4 degrees of timing and add 8 % fuel at the -6 degrees. It set the P1514 code. I have twin turbos on a 347 cu in 01Z06 A4. It hits around 15 psi boost around 6000 rpms.
I'm pretty sure the 8% fuel increase is what's pushing you into the 1514, it will likely go away with scaling. I'd scale by 20% (multiply ifr and ve by .8) All spark tables that reference g/cyl will need to be shifted (don't multiply by .8) to reflect the new , lower g/cyl values. Of course , first make sure Engine Diag -> General -> Calc Airmass P1514 table is maxed out.
well, i have been told about that as well. i have a 99 pcm. in my case there is no such limit. im running well over 1.6 g/cyl now.
i went back to my non-rescaled tune, mainly because i didnt want to have to deal with all the transmission adjustments.
edit: changed 16 to 1.6 g/cyl.
I did the .8 times the complete IFR table, complete VE and Boost VE tables. I won't be able to take it for a trial run for a couple of days because of a minor surgery this morning. I'll will report back the results after a run and logging things. The results may help someone else so I do want to end this conversation with said results.
I currently have this issue also, when holding the throttle steady before making a pull. I came across this and currently working on it.
long story short, reduce the IFR and VE accordingly
https://www.corvetteforum.com/forums...ine-power.html
https://forum.efilive.com/showthread...ighlight=p1514
#33
