Data Logger/Scanner Phone Apps
#41
Hey C5Natie,
I've had Torque for awhile (used it with my old car, an RX-8). I hooked it up over this weekend to my '02 C5 Z06 and I'm not getting any readings for knock, or the front O2's like you are and I'd really like to get to those.
Did you have to do anything special to configure to get Torque to work with your 'vette? Any special configurations or settings?
Thanks for the videos and the post, they were really helpful.
Try the torque scan plugin and see if the app is reading the o2's.
#42
If youre looking for a gauge reading the actual knock detectors, i dont think the app has one. You can look at your timing and if youre familiar with your tune you can go off of that. The knock detector plugin should show you tho if the knock sensors pick up any detonation at wot.
#43
Yeah, that's really weird. None of the O2 sensors are showing up as available with the green-highlight. I'll have to look again.
Is there anything specific in the Vehicle Profile that you set? There are a couple settings in there that I was curious about:
As far as knock goes, I might email the plugin author to see how he's calculating that. My guess is he's polling the TPS and Timing Advance somehow, if timing advance is being retarded then it's probably safe to assume knock has been detected. I'm just used to pulling knock directly from the ECU, but I've never tried it on a Corvette before
- There's one called Use Alternate OBD Header, which I have unchecked.
- And a second about the preferred OBD2 Protocol, which I've got set to "Automatic - Thorough Protocol Scan" at the moment.
#44
Auto protocol should be ok thats what i have it set to. Try the alt header, restart app and see if it reads them, I havent tried it. Try looking at torque scan to make sure the app is reading the sensors. Should say recieving data iirc. The car must on tho.
#47
I'll have to give it another try, I've been using Torque for a couple weeks and haven't seen any data from the O2 sensors at all.
I used Torque on another car for quite awhile. I wonder if there's something incompatible because of my past settings. To be safe, I wiped the app's data, uninstalled it and re-installed it. That should take care of any past settings.
I assume that if the O2 sensors were bad or if the ECU couldn't talk to them at all, I'd have some sort of Check-Engine-Light. But you never know, I bought the car used so some lurking issue might be out there.
When I've got some more time this week, I'll tinker around with these settings and let you guys know what (if anything) I had to do to get this working correctly.
Again, thanks a bunch for all your help! I really appreciate it.
#48
guys, are any of you successfully using this adapter? Or all using the larger ones?
#49
Amazon.com: V1.5 Super Mini ELM327 Bluetooth OBD2 OBD-II CAN-BUS Diagnostic Scanner Tool: Everything Else
http://www.ebay.com/itm/Auto-ELM327-V1-5-Interface-Bluetooth-OBD-2-OBD-II-Car-Diagnostic-Auto-Scanner-/230914902258?pt=LH_DefaultDomain_0&hash=item35c399c8f2#ht_3468wt_1255
#52
Quite odd, that mini works on all my other cars, just not the vette. I did purchase the larger one but seems a bit large to have hanging there.
Dave
Dave
