Every Tech should have this LS Timing cover Alignment Tool!
Supporting Vendor
AlignIt Tools are to designed to align the Timing Cover & Rear Main Cover and install the Seals on all LS base engines.
Whether your a Pro or a Do Your Own Repair kind of guy, here is a simple but very effective tool to help you make
easy work of installing your LS1-2-3-6-7-9- LQ4-LQ9- 5.3-6.0 Timing and Rear Main cover and seals. Works with all LS based engines!
The AlignIt tool gets the timing & rear main covers centered perfectly with the crank and installs the seal in seconds! Check out the videos.
Having the seal centered accurately with the crank minimizes the chance of seal leakage.
Buy more than one of the AlignIt Tools and save!
http://www.saccitycorvette.com/AlignItTools.html
Here is a video that shows how simple it is to use. Tools used in videos are prototypes. The tools we sell are much nicer!
Installation with Oil Pan off.
SacCityCorvette LS1 2 3 6 7 timing cover tool. - YouTube
Here is a Video the shows installation of Rear Main cover and seal with the Oil Pan on.
AlignIt Rear Main Cover Tool - YouTube
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Supporting Vendor
The AlignIt, aligns the timing cover with the crank in seconds and then makes installing the seal easy!
Supporting Vendor
Hi Everyone,
We have the AlignIt Rear Main Seal Tool ready to go! We have a instructional video of it on our website. :Cheers:
http://www.saccitycorvette.com/Timin...nmenttool.html
Thank you,
Christian
Thank you,
Christian
Supporting Vendor
These tools ensure alignment accuracy and time savings!
Supporting Vendor
Supporting Vendor
You really want to do the job right the first time to avoid any leaks
Supporting Vendor
Supporting Vendor
The Hub Simulator Tool is for those that do not want to remove the seal.
It simulates using your hub to align the timing cover with the seal in place.
Supporting Vendor
The AlignIt tools get the covers centered perfectly with the crank and install the seal in seconds.
Supporting Vendor
Planning a cam swap or engine rebuild? AlignIt Tools can help with the rear main, timing cover and seal install. And get it done right the first time with less chance of leaks!
Supporting Vendor
Here is a simple but very effective tool to help you make easy work of aligning your LS1-2-3-6-7-9 Timing Cover, Rear Main Cover. They even install the seals.
