C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Converter Lock/unlock - what???
Old 09-30-2013, 10:34 PM
reactor2
reactor2's Avatar
Default Converter Lock/unlock - what???
98 'A4
I have a decent size cam (228/232 .571/.573 112) and a decent stall (Yank SS3600). When in 4th, my converter will lock/unlock when RPM < 2300. My understanding is that this is because the computer is interpreting the cam/stall as a misfire. I should note that the converter rarely unlocks unexpectedly when in 3rd.
As per many threads I maxed out the misfire tables (HPTuners):
Engine Diagnostics->Misfire
a)Revolution Mode
1)Low RPM
2)Medium RPM
3)High RPM
b) Cylinder Mode
1)Medium RPM
After I did that my converter failed to lock at all! It wouldn't lock in 3rd or 4th no matter what. I replaced the stock values and it went back to locking up.
What's going on? I've read at least 10 threads that talked about maxing out these tables to stop the computer from unlocking the converter because of a "misfire".
What am I doing wrong? Why would maxing these table result in a converter that never locks?
Old 10-01-2013, 12:06 AM
RonSSNova
RonSSNova's Avatar
Originally Posted by reactor2
98 'A4
a)Revolution Mode
1)Low RPM
2)Medium RPM
3)High RPM
b) Cylinder Mode
1)Medium RPM
Rather than try to fiddle with those numbers, I adjusted the misfire detection to just have the PCM ignore misfires.
Max ECT to 0
Min ECT to 284
Never an issue since.
Ron
Old 10-01-2013, 12:34 AM
reactor2
reactor2's Avatar
Max ECT to 0
Min ECT to 284
Ron
I'm new to HPTuners. Where can I find those values?
Old 10-01-2013, 01:04 AM
RonSSNova
RonSSNova's Avatar
Same screen as the tables
Old 10-02-2013, 01:29 AM
reactor2
reactor2's Avatar
That worked! Thanks. First time my converter stayed locked for over 3 years!
Old 10-02-2013, 05:34 PM
RonSSNova
RonSSNova's Avatar
You are welcome
Old 10-04-2013, 08:52 AM
0Josh@SpartanLSX
Former Vendor
Josh@SpartanLSX's Avatar
What really needs to be done is raising your lock speeds, and disabling converter lock in 1st-3rd gear. There's absolutely no reason for the converter to lock in 3rd as that's usually a gear you're in while crusing in town. Overdrive is the only necessary gear for converter locking.
From a driving experience standpoint, it is absolutely amazing how "snappy" and responsive the car can become tuning the transmission properly. It will also do wonders for driveability if the transmission isn't locking at silly low rpm's and/or silly low mph speeds.
Old 10-08-2013, 10:17 PM
CactusCat
CactusCat's Avatar
And all of this is accomplished thru the tune? If so, I'm going to have my tuner take care of this for me.
Old 10-15-2013, 11:40 PM
0Josh@SpartanLSX
Former Vendor
I apologize for the delayed response to your question. Been slammed at the shop.
Yes, this can all be done in the tune. Find a tuner that is savvy with PROPERLY tuning the 4L6x transmissions. A good trans tune can make the car feel totally different (in a good way) and a bad one can make the car a dog too.
To Converter Lock/unlock - what???
Quick Reply: Converter Lock/unlock - what???
