How to swap ECM on a C5 (ECU)
my ecu is tuner lock
i just bought a similar ecu from a chevy astro with the same code
what's the procedure to swap the ecu with my vin...
i cant find nothing on the web
You will need to flash in the correct tune for your car using EFILive or HP tuners. Either software can rewrite the VIN # as well. I would probably set the "Vehicle Anti Theft" setting to disable just to make sure the ECM plays nice with all of the other modules.
