Idle problem one minute later after cold start
hi everyone
Have a 98 corvette. put brand new transmission oil pump on it. There was no trouble with the engine before i changed it. When I changed and start the engine cold, it idles perfectly for just 1 minute. after one minute, AFR goes 7,62 to 15,70 g/sec when idling. Changed the sparks and plugs, coils. I don't know what to do and I'm so confused. Diagnose device says; Air System Fault (Bank 2). Controlled the air pump, when I cold started the engine, it works properly for just 1 minute. After air pump stops, it idles really bad, raw fuel on the exhausts.
Waiting for your replies. Thanks.
And i noticed yesterday, when idling goes bad after 1 minute, passenger side injectors just dont work, I'm unplugging them when idling, and it's not going worser. Still same, but when I unplugged the drivers side injectors, it stops. If this information helps...
Now i got what was the problem is and i solved, oxygen sensors was cross connected,
NOW I have a really big problem, when i lift the car from the backside it starts and runs great in the air, when i got car on the ground it wont start. Changed the fuel pump. Please someone help me about this
St. Jude Donor '13-'14-'15
OMG Plugs Coils Wires Fuel Pump ?? Just don't randomly change parts without knowing what's wrong--Guessing is expensive--It would have been cheaper get a diagnostic check done at a shop for $100 to pinpoint the exact issues----
As for your new problem I've never heard of such of a thing on ANY car !!
What exactly do you mean by car won't start ?
Won't turn over with the starter ?
Ignition switch doesn't light up the dash?
Engines turns over with starter but won't start ?
