C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Fuel pump help
Old 07-11-2014, 05:19 PM
JIMS SVT
JIMS SVT's Avatar
Default Fuel pump help
I have a 99frc that I'm about to drop my new motor in. It.should be around 500rwhp N/A. It'll have 42lb injectors also. Will the stock pump hold up to this power level? Or do I need to look into another option?Maybe boost-a-pump? Thanks for any advise
Jimmy
Old 07-15-2014, 09:27 PM
tblu92
tblu92's Avatar
St. Jude Donor '13-'14-'15
I think YES it would be a good idea to get an aftermarket Hi Volume fuel pump ( not that expensive)
But You may run into other tuning issues with a 99 with 500 RWHP
A stock 99 MAF table ends at 12,000 HZ ---Often not high enough for certain Hi HP applications---Only way is to check with a data logger or real time scanner where your eng ends up at WOT----
This is only if you use the MAF and the STOCK open/closed loop tune-----
Your options would be to run a "speed density" tune or a Semi open loop tune
Old 07-15-2014, 10:06 PM
JIMS SVT
JIMS SVT's Avatar
It was tuned in SD on the last setup. Itll be sd thos time too. So Can I just put say like a 255 in the tank?
Old 07-16-2014, 12:14 AM
tblu92
tblu92's Avatar
Yes--- The boost-a pump is almost as much !! and may not be enough--why gamble--time and energy--New pump---done deal !
Old 08-15-2014, 09:32 PM
JIMS SVT
JIMS SVT's Avatar
Ended up doing a AEM 320. The stock screws that hold the pump hat to the tank really suck to get out too!
Old 08-18-2014, 10:53 AM
Dcollins3208
Dcollins3208's Avatar
Did you have to modify anything to fit the AEM pump?
Old 08-18-2014, 11:04 AM
JIMS SVT
JIMS SVT's Avatar
The little pump on the bottom of the basket won't work with the new pump. So i took the flapper off son it had a better chance of fuel to get in. Other than that it was pretty much the same.
To Fuel pump help
Quick Reply: Fuel pump help
