C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Can you log fuel pump voltage in tuners of efi?
Old 07-22-2014, 12:29 PM
Chicago1
Chicago1's Avatar
Default Can you log fuel pump voltage in tuners of efi?
I want to log my fuel voltage under boost and my understanding there isn't a way to log it but wanted to check. My next thought is tapping into the wire and running it in cabin to a volt meter.
Old 07-23-2014, 03:39 PM
Chicago1
Chicago1's Avatar
anybody?
Old 07-23-2014, 10:56 PM
directnosfogger
directnosfogger's Avatar
I wonder if you could run a line right into one of the inputs on the tuner. I would first check the voltage with a multimeter, but theoretically you could log it with a custom input right?
Old 07-24-2014, 10:16 AM
Chicago1
Chicago1's Avatar
^ I have no clue how we are going to do it is tap into the line and run it in cabin with a mutimeter. I don't have it it's a friends that was going to bring it over to log my car. I have searched and I havent seen a yes or a no. I emailed efi to see what they say. He's unsure also he thought we could but is not sure
Old 07-24-2014, 11:11 PM
directnosfogger
I'd be curious what the span of volts that may be seen. Considering a wideband usually reads from 0-5 volts, if you hook up a multimeter to this and can identify the high/low output you should be able to get a sense for what an input on a tuner would see.
Where is a GM engineer when you need one??
To Can you log fuel pump voltage in tuners of efi?
Quick Reply: Can you log fuel pump voltage in tuners of efi?
