C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Vacuum leak affect tune?
Old 09-14-2014, 07:29 PM
marvinseah
marvinseah's Avatar
Default Vacuum leak affect tune?
I have a 2004 C5Z that is H/C'd. After getting it tuned I noticed the 1/8" hvac vacuum hose that attaches to the rear of the FAST intake was disconnected. I reconnected it and the car drives abnormally worse. It would hunt for idle and surge a lot more than before. What I am curious about is if the car was tuned with a vacuum leak would fixing the leak cause drivability issues because it throws off the "tuned" fuel trims?
Old 09-14-2014, 08:19 PM
aaronc7
aaronc7's Avatar
do you have the ability to datalog or see what's going on with the fuel trims?
Old 09-20-2014, 03:19 AM
tblu92
tblu92's Avatar
St. Jude Donor '13-'14-'15
Yes a vacuum leak allows "unmetered air" to get into the eng so it is not making fuel corrections for that air as the ECM doesn't know it's there
To Vacuum leak affect tune?
Quick Reply: Vacuum leak affect tune?
