Hinson Motorsports A&A Supercharger Install, Dyno #s, & Build
Former Vendor
Hinson Motorsports rolled a 2003 Z06 into the shop this morning to install a laundry list of new goodies:
- A&A Supercharger Kit - V3 SI Trim
- Kooks 1 7/8 Stainless Headers
- Kooks 3"x 3"x 2.5" Off-Road X-Pipe
- McLeod RST Twin Disc Clutch
- McLeod Steel Billet Flywheel
- Remote Speed Bleeder
- GM Slave Cylinder & Pilot Bearing
- ATI Crank Pinning Kit
- New Harmonic Balancer
- ARP Bolts
- HINSON Spark Plug Wires
- HINSON Spark Plug Heat Boots
- HINSON Urethane Engine Mounts
- SLP 160* Thermostat
- Comp Cams LS Rocker Trunion Upgrade
- Lunati LS .660 Lift Dual Valve Springs
Stay posted for daily updates on how this project is coming along. Visit www.hinsonmotorsports.com to check out all the SPECIAL WEB PRICES we have on every one of these items we are installing on this car.
2003 Z06 Project Starts with Base Dyno Numbers 100% Stock Z06
2003 Z06 Stock / Base Line Dyno Numbers
100% Stock For Now
A Table and Floor Full of "The Good Stuff"
Former Vendor
So as promised we have a daily update for you. For purchasing the items in this thread see the links posted in earlier thread or visit our site for a full line of products www.hinsonsupercars.com
Today we have added a few other goodies to the C5 Z06:
HINSON C7-R Timing Chain
Throughout the course of the day we have installed:
McLeod Clutch and Flywheel
Pilot Bearing
Pinned the Crank
Balancer
ARP Crank Bolt
Trunion Rocker Upgrade
Lunati .660 Lift Dual Springs
160*F SLP Thermostat
MISC Seals and Gaskets
Cleaned the engine and got it ready to put back in the car
McLeod RST Clutch and Billet Steel Flywheel
Lunati Dual .660 Lift Valve Springs
HINSON Urethane Performance Engine Mounts In Yellow
HINSON C7-R Seamless Timing Chain
Pinning the Crank
Comp Cams Rocker Trunion Upgrade (Left) Stock GM (Right)
Comp Cams Rocker Trunion Upgrade Installed
Stay tuned for more. Tomorrow we will be installing all of the brackets, intercooler, putting the engine back in the car, and repairing the infamous C5 wiring harness damage we are all so familiar with.
Pilot Bearing
Pinned the Crank
Balancer
ARP Crank Bolt
Pinning the Crank
Former Vendor
Daily update time.............Ya'll ready? So we have been hard at it again today with this beautiful Z06. Heres where we are with it:
Installed the torque tube and trans
Upgraded the trans mound to a HINSON TRANS MOUNT
Installed the engine back into the car
Wired and plumbed everything back in
Fixed some wiring issues we discovered
Installed the A&A Intercooler
Installed all the exhaust
All in all worked on getting the car back to one piece and ready to fire up.
So as this projects nears the end its that time............. Lets start hearing the HP predictions.
A&A Intercooler
HINSON Transmission Mount
Back In One Piece - Look at All the New Stuff
Kooks 1 7/8 Headers Off-Road Mids & X-Pipe - Makin' Sure She's Gonna Talk to Ya
A&A Intercooler
