Help needed with "check engine"
Hi guys.
I need help and I need the collective knowledge of the forum to try figure this out.
First some history leading to this…
I got a set of longtube headers about three months ago. When I did that, the car was running great. However about a week later it threw a code and a Check Engine light for the air pump, which was understandable, because I removed it. About two months ago I also started working on putting wide fenders on the car (which turned into a nightmare). While I was waiting on the paintshop I decided to take the computer out and ship it to ECS to get it reprogramed. The reprogramed computer went in the car about two weeks ago. So here is where the issues started.
The car is more responsive, the temperature stays in check and I love it….Well kind of. The car has a hesitation right around 1600 RPM and at low RPM sounds kind of rough.
Today driving my wife to work, the check engine light came on. On my way back I stopped by Autozone to check the codes. Four things showed up.
1. Low fuel sensor
I know the C5 is notorious with issues with this and it doesn't really bother me. I keep the tank full most of the time and don't really rely on the gauge
2. P0133 Oxygen Sensor Circuit Slow Response Bank1, Sensor1
This is chinese to me. What does that mean? What can cause it? And the consequences could be?
3. P1134 Heated Oxygen Sensor Transition Time Ratio Bank1, Sensor1
Same questions as the P0133
4. P0153 Oxygen Circuit Slow Response Bank2, Sensor1.
Now this one I also don't understand, but it is really puzzling to me. I may be wrong, but as far as I know, bank 1 is the front sensors and bank2 is the rear sensors. Well, if ECS reprogramed the computer and eliminated the rear sensors (part of their tune up) then why am I getting any codes for the rear sensors?
Please, any advise or help would be greatly appreciated.
Thanks in advance.
1. Low fuel sensor
Thanks in advance.
Hi guys.
1. Low fuel sensor
Thanks in advance.
1. Low fuel sensor
Thanks in advance.
The codes you are getting are for the front O2's which are called Sensor 1. The rears are called sensor 2. Bank 1 and 2 reference the drivers/passenger side. With LT's you will sometimes get these codes as the OS'2 are moved a bit further from the exhaust port.
Will need to see if the installation of the LT's/O2's has an issue or if just "slow" due to the new location. In some cases we shut off these codes. You can discuss this with ECS.
Ed M
First off I would call Doug or Chris at ECS and I am sure they will be able to help you.
Ed M
Ed M
My O2s are at the same place as the OEM. No extension harnesses or anything.
