efilive and zeitronix
St. Jude Donor '13-'14-'15
i did and they say they dont have experience with zeitronix, but it "should" work. a tuner sais it will not. zeitronix anwered they have an analog out put, but didnt get back on the serial issue.
Given the outputs, I would think it would workthe same as any others, You may need a null modem adapter if you use the serial output from the Z to the serial inout of the EFILive.
No reason it shouldn't work, it's linear output is as follows 0 volts = 9.6 AFR and 5 volts = 19.6 AFR. Id assume you just need to set the voltage parameters in your software.
I tune with EFIlive and it'll work, what you'll have to do is make your pids. Look up creating pids in EFIlive's forum, since the Zeitronix website says it'll output a linear signal you'll be able to make it work. I've had to do the same thing to input a dyno's wideband before.
