Good tuner near Mississippi?
I need you guys to recommend me a good tuner close to my area I have a car hauler so I can have the car pulled out of state if need be.
I have a 98 c5 6 speed with 60k miles. I'm not 100% on my build just yet but it will be something along these lines.
A&A v3 si or t trim or ECS novi 1500
CCP jam cam or custom blower cam
Alky single nozzle meth injection
Valve springs
Ls7 lifters, trays
Ls9 head gaskets, arp head studs or bolts
Timing chain
Meiling oil pump
1 7/8 long tubes with 3 inch exhaust
Comp turnin rocker arm upgrade
Pushrods
I'm shooting for 600whp hopefully this will get me there. I've heard the 98 model ls1 cars can be tricky to tune so I need some recommendations on a good tuner I can carry my car to. I will be doing all the work myself and I'm located in Madison ms.
Valve springs
Ls7 lifters, trays
Timing chain
Meiling oil pump
Pushrods
[QUOTE=Vince98;1588552539]I need you guys to recommend me a good tuner close to my area I have a car hauler so I can have the car pulled out of state if need be.
EPS in Baton Rouge is one of the best tuners in the country! You built an awesome car!! Post the dyno sheets when that bad boy is done!!
c6reaperx
Did you ever find a good tuner? I am in laurel and looking now. Hinson in Irondale Al did not seem too hopeful about getting me in.
Valve springs
Ls7 lifters, trays
Timing chain
Meiling oil pump
Pushrods
Valve springs
Ls7 lifters, trays
Timing chain
Meiling oil pump
Pushrods
I use Dynospeed in Memphis TN. Ask for Josh. They will tune your car for drivability and for WOT on the dyno. Or get in touch with Brett (blownbluez06) on these forums and he can tune it via your laptop and your HPtuners is you have your own wideband. Brett is one of the very best LS tuners out there imho. I have used both and I believe you would be happy either way.
Excellent choice. Brett tuned my car last december by logging into my laptop and and using my HP tuners pro. He is a super smart guy and knows his stuff. He will take the required time to get everything dialed in that many shops just will not take the time to do because they are looking to get the next car in and yours out.
Cruise-In IX Veteran
Futral Motorsports in Walker, LA does a good job and should not be too far for you to go. I know he has worked on my car as well as Detoxx and Slo-poc here on CF.
c6reaperx
