Crankshaft sensor relearn
Does anyone know the procedure for a crank sensor relearn with HP TUNER software? I am repairing some melted wiring and decided to replace my crank sensor while my headers are off and starter is out. I know they almost never fail except if had p0337 code come up 2 time and decided to do it . Rather not have to take it to dealer and use a tech 2 if possible
Thanks for advice
Pozzest
Thanks for advice
Pozzest
Open scanner, open VCM controls (on/off 100%) on toolbar, special tab, CASE Learn and then follow on screen instructions. You will have to rev it up slowly to redline, however, I have never actually seen issues that would necessitate doing this. It's not something you do on a newly built engine so I never did it to my current setup and no issues.
I just returned from the dealer, they say the small oil leak, (so small it does not drip, just oil creeping down the side), is coming from my crankshaft sensor. They wanted $400 to replace! ($320 labor, $80 part). I see the part is $25 at RockAuto.
How hard can it be to replace? Is it just a simple remove the wire connector, unbolt/bolt new one on, reconnect wire and go? What is this about "relearning"?
