Stroker knocking off after flashing stall
If I slightly flash the rpms (while in drive) to 2500-3000 and then let completely off the gas, the rpms will just fall to 200 and then the car will knock off.
Its very annoying when turning the wheels over in the waterbox. As soon as I let off the gas, knocks off. Same thing for burn out. Im having to ride the brake to the starting line and keep it stalled up to 1500-2000 to keep from knocking off.
Normal driving it does fine. Cold starts = knock off until > 160*.
I performed the idle relearn procedure, but it did not work. Afterwards, I powerbraked it, and just flashed it enough to just break traction. Then I let completely off the gas....car went rpm hunting and knocked off.
Thanks,
David
Thanks,
David
The 97 computer calculates when to fire 4 spark plugs and when to open and close 4 fuel injectors each rotation of the engine. Your problem isn't because the computer is too slow.
