Hp tuner TCC need advice
I have a xls excel with all my value
i need some help to customize my settings
can someone help me out..
i dont want the TCC on 2/3
and i dont want the tcc to be apply on 4 before 43mph
if i send my value, can someone double check it for me.
it will be appreciate it a lot !!!
thanks
thanks
St. Jude Donor '13-'14-'15
thanks
thanks
To do this all you have to do is to input the MAX MPH in the entire 3rd gear lock up table--- and in the downshift table also input the MAX MPH---this will eliminate the 3rd gear lockup
Now to raise the 4th gear lock up from the stock 38 MPH to something higher (I recommend 50 MPH up to apprx 33% TPS) simply change those values----From 33% on up add 5 MPH at each box until you reach 85 MPH usually around 80 TPS after that leave all of them the same 85 MPH----
In the downshift table----copy and paste the entire table from the 3-4 upshift table----THEN subtract 13 MPH to the entire table
And finally----In the TCC Pulse width modulation table set the entire minimum table to read 66% and the entire MAX table to read 98%
That will give you firm crisp TCC lock up
