Airaid Filters & Intake Systems on SALE! | C5 Corvette | JDP Motorsports
Former Vendor
JDP Motorsports is proud to offer, use and install AIRAID Intake systems and Premium Filters!
OEM Replacement filters
AIRAID® Direct-Fit Replacement filters fit in the factory air box and are drop-in replacements for stock paper filter elements. Constructed using the same premium materials used in our Cold Air Intake Kits, these filters offer significant improvements in airflow and filtration while being washable and reusable. Why throw money away on a paper filter each time the old one gets dirty when you can upgrade to a serviceable AIRAID® Premium Filter for often less than the cost of two stock replacements? AIRAID® Direct-Fit filters require no modifications and installation is as simple as replacing a stock filter.
Airaid - Oiled Replacement Filter - 1997-2004 C5 Corvette - 850-118 - $73.90
Airaid - SynthaMax Dry Flow Replacement Filter - 1997-2004 C5 Corvette - 851-118 - $79.90
OEM Replacement Upgraded Filters
Airaid - SynthaFlow Oiled Replacement Filter - 1997-2004 C5 Corvette - 860-042 - $172.90
Airaid - SynthaMax Dry Flow Replacement Filter - 1997-2004 C5 Corvette - 861-042 - $183.90
Installed (connects to factory intake tube)
Intake Systems
It is a proven scientific fact that cold air is denser than hot air, which means that an engine breathing cold air is going to make more power than the identical engine breathing hot air. The quest for cold air is what drives the AIRAID® Cold Air Dam Intakes. The CAD Intakes retain the stock filter location but give the stock intake system a big boost with the addition of a huge air inlet that provides a steady, free-flowing supply of cold air. This is done via Cold Air Dam panels, which mount in the factory air box location and utilize any factory cold air inlet ducts that are present, while adding additional cold air passages to the filter. These panels also keep the filter isolated from the hot engine compartment air by sealing to the underside of the hood via blade-style weatherstripping. Each AIRAID® Cold Air Dam Intake is designed specifically for each vehicle application and offers a simple, trouble-free installation using simple hand tools. Like the rest of the AIRAID® systems, the CAD Intakes are Made in the USA and include all the necessary installation hardware as well as easy-to-understand instructions written with the do-it-yourselfer in mind.
Composite systems
Airaid - Intake System (SynthaFlow Oiled Filter) - 2001-2004 C5 Corvette - 250-292 - $229.90
Airaid - Intake System (SynthaMax Dry Flow Filter) - 2001-2004 C5 Corvette - 251-292 - $337.90
Installed
Carbon Fiber Systems
Airaid - Intake System (SynthaFlow Oiled Filter) - 2001-2004 C5 Corvette - 250-292C- $624.90
Airaid - Intake System (SynthaMax Dry Flow Filter) - 2001-2004 C5 Corvette - 251-292C - $632.90
Installed
Please feel free to call, PM or email us anytime with questions. We appreciate your interest and look forward to working with you!
Best regards,
Tyler
888-308-6007
sales@jdpmotorsports.com
Intake Systems
Composite systems
Installed
Installed
Best regards,
Tyler
888-308-6007
