Spark plugs
Spark plugs
I bought this 98 Vette that was built into a 383 stroker. I have no idea when the plugs were changed last. The manual calls for .60 on the stock engine. Should the stroker be gapped differently or as the manual instructs.
St. Jude Donor '13-'14-'15
TR55 NGK's are the most used performance plugs---either using the standard plug or in some combination of Platinum or Iridium---
spark plugs
Thank you very much. I wasn't sure since it's a stroker with long tube headers if the gap was different or not. I appreciate your reply.
for heads/cam and other various mods for N/A engines we usually go with TR6C copper at 35 thou ish..... won't make much diff but I think it's the most popular...
