Flex Fuel C5Z...
Flex Fuel C5Z...
I know this can be done, does anyone have a tuner who is familiar with the process and will offer their services for a paying customer? I know I'll need a different ECU, but have also read there's a lot more involved than just an ECU and OS change. Wish it was as simple as it is for the C6 guys...
St. Jude Donor '13-'14-'15
What ECM do you currently use ?
It's an LS2 short block out of an 05 C6 so it's a 24x motor. I use the stock 411 C5Z PCM because an ls2 only needs a cam position sensor and knock sensor lengthening harnesses to run in a C5, as long as the reluctor wheel has 24 teeth.
