What Gear Is My Auto Transmission In ?
I'm reviewing a log of a recent run. Where can I find which gear the transmission is in? This is a 4L60.
If I close out the log file I'm able to add (right-click and then "Insert") the gear PID, however, once I open my log back up the gear PID is gone.
WTF. Any ideas what I'm doing wrong?
Last edited by mdaniel; 06-28-2015 at 07:58 PM. Reason: Appended additional detail.
St. Jude Donor '13-'14-'15
You have to add the PID for "current gear" to be able to have it recorded
looking at your data log--you went 122 MPH so my guess is that you were in 4th gear--Depends on your rear gear ratio and how far you went to hit 122----With a 4l60 it is easy simply to count the shofts as you increase speed
Yeah - that was the problem - I hadn't added the pid before I started logging.
I lost 3/4 gears in the trans on that pull.
It's a 3:42 gear.
It's a 3:42 gear.
No often more pressure will make it worse-----I've had the best results with weak transmissions by lowering the shift times 1st to like .20
and then by lowering the "force motor current" tables----- The FMC tables command how fast the solenoids snap----The larger the number the slower the shift--The table is scaled by trans temperature and by trans pressure----I typically will SUBTRACT like 15% in the FMC table from just past 0% all the way to the end (like 95 PSI) this will create quick crisp shifts--See if that helps--If it does not---most likely it's bad news---
The FMC table dictates how quickly the solenoids snap-- and do not alter pressure per say but a quick solenoid time will allow the pressure to ramp up faster----The FMC table is similar to the PWM table for the TCC---- The stock TCC solenoid snaps very slow using a commanded slow 10% of max value---Most all tuners will set that number to like 90% of max value which makes the TCC shift firmly--The TCC PRESSURE is not changed by altering the PWM tables--same as the FMC tables for the trans gear shifting--
Well I believe the trans pressure are controlled by the "base trans pressures per gear" tables----They are scaled by engine TQ---as the TQ goes up so does the pressure----At cruising speeds the pressure is low--less than 20 psi---at WOT the most it can command is 90 PSI--
The Force Motor Current table that you are tweaking is simply the translation between desired Actuator Feed Limit Pressure and how much current is required to achieve that given the tranny fluid temp. Like it or not, you are indeed changing hydraulic pressure as THAT AND ONLY THAT is what automatic transmission clutches respond to and in many cases affects how quickly valves react. Electrical inputs into the solenoids based upon lookup tables that you are tweaking are but the means to control the hydraulic pressures. You are getting the results that you want but not for the reasons that you state.
