C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Why is the default c5z tire diameter setting set to 25.21"?
Old 06-29-2015, 06:42 PM
Socko
Socko's Avatar
Default Why is the default c5z tire diameter setting set to 25.21"?
So I was at the track 10 days ago and i hit my rev limiter in 4th. the weird thing was my speedo said i was going 144.7. I don't have a tuner yet but my car is tuned. So i looked in the calibration and it says my tire diameter is 25.21". I assume this is supposed to be the rear wheel diameter so I checked a factory tune and it was the same. Why is it set this way as the stock c5z rear tire diameter is 26.1? even the front is over 25.21?
Thanks!
Old 07-05-2015, 11:33 PM
tblu92
tblu92's Avatar
St. Jude Donor '13-'14-'15
Even a regular C5 has the tire diameter somewhat smaller in the tune than actual Tune says 26" and the actual stock tire size measures 26.50
Also be aware that a tire can have the same P metric size but different manufacturers can have different tire heights----
GM by making the tire size smaller in the tune than actual size will show a larger MPH on the speedo--maybe they do this to keep us from getting tickets ??
Old 07-06-2015, 06:53 PM
Socko
Socko's Avatar
making the tire size smaller actually makes the speedo read under how fast you are going, as you are going farther then you think you are. C5Z stock ring at 3.42:1 and 1:1 4th trans ratio with a 295x35/18 measured at 81.75" circomference so 26.0" diameter yields 149 by my math at 6600 rpm. Speedo says 144.7. At 65 i think its only 2 mph though as they are both flat lines on a different pitch, but i am really doing 67. So the damn car is trying to get me arrested!
Old 07-07-2015, 02:11 PM
tblu92
tblu92's Avatar
OOPS !! Sorry you are correct I got it backwards--sorry---Well then I have no idea why they do it that way !!
Old 07-18-2015, 11:51 PM
SVT_Z06
SVT_Z06's Avatar
Thanks!
Guys,
That number is the LOADED TIRE RADIUS.
You can use the following formula (295/35-18 to 305/35-18):
26.4 / 26.1 = 1.0115
25.21 * 1.0115 = 25.4999
New actual height / old actual height = difference
Old actual height * difference = new loaded radius
Enjoy
Old 07-19-2015, 12:00 PM
Socko
Socko's Avatar
Originally Posted by SVT_Z06
Guys,
Enjoy
I was assuming their must have been some logic to it. Thank you!
Old 07-19-2015, 12:11 PM
SVT_Z06
SVT_Z06's Avatar
No problem, man.
V
To Why is the default c5z tire diameter setting set to 25.21"?
Quick Reply: Why is the default c5z tire diameter setting set to 25.21"?
