Using a Tech 2
Using a Tech 2
I am adding factory fog lights to my 04 Z06 and need to know how to enable this functionality in the BCM using my Tech 2. I have already installed the necessary wiring (not connected yet) switches, and lens's. I would like to know what to do before starting this type of modification.
I have an Audi TT and the VAGCOM software. I have enabled the cruise control function with it, so I have very limited exposure to this arena and would like some guidance.
Any help would be seriously appreciated!!
Some of the wiring for foglights is already installed in the Z06, makes for less different wiring harnesses in production. If you are using the factory foglight switch, which just replaces the trunk switch when plugged in, the wiring to the relay and fog fuse is already there, including the relay and fuse. There is no need to do any programming to the computer, everything will work just the same as OEM. I did this mod to my Z06 years ago. BTW, I also have a Tech 2 and didn't need it to do this mod.
Igot this link form another member. If you have a Tech II it is invaluable in ease of use
Fog Lamps – Body > Body Control Module > Special Functions > Output Control > Lamp Test
Fog Lamps – Body > Body Control Module > Special Functions > Output Control > Lamp Test > Exterior Lamps
Fog Lamps – Body > Body Control Module > Special Functions > Output Control > Light Test
http://service.gm.com/userguides/english/t2paths-en.pdf
In case nobody read my post, if you use the factory switch and wiring which will already be there, you don't need the Tech 2 to make the foglights work.
@ striper - I read it and you are 100% correct sir!, but I will always take more information than not enough!
@ rclinton - The pdf file that was so generously posted is worth it's weight in gold! Plus, provides with good learning ability.
I recently had to have the ignition cylinder lock replaced. Had I not been on vacation returning from the 24 Hrs of Lemans, I would have troubleshot and fixed it myself. However, when a certified Vette tech is available with dealer resources and a friend who lives near the dealer speaking French...I left the car for repair. Being out of the States and on my own, I want the ability to identify and repair as necessary. With the Forum Team (ahem, guys like you) and these tools I feel confident I can maintain my beast in Italy and possibly help out a couple new friends in the process!
Ok, I have front fog lamps and have converted them to HID's because I bought a kit a year ago when I first got this idea.
Now I am connecting the rear fog lamps and that circuit just won't engage unless I force it with a light test as listed above for the front, but selecting the backs. Is this going to take an RPO upgrade or something like that? If so, how do you do that please?
