C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
My Tach and Speedo going crazy
Old 07-26-2015, 06:05 PM
mrx_33k
mrx_33k's Avatar
Default My Tach and Speedo going crazy
Hey guys need some help here. My track and Speedo r going crazy under normal and load driving. Also some tines it feels like it wants to turn off on me. Any I dead on what it could be?
Old 07-27-2015, 12:46 PM
dadaroo
dadaroo's Avatar
This should be posted in the Technical section, I never look here but just happened to see it when I pulled up the Forum to look. I have worked on a number of IPC issues but this is unique since it involves just those two different inputs. Normally all the gauges go crazy or just one. Not at home now.
Pull your Dash DIC codes and see what it shows.
Mr. Sam
Old 07-27-2015, 01:16 PM
mrx_33k
mrx_33k's Avatar
I think it might be the vehicle speed sensor vss.
Old 07-27-2015, 02:03 PM
tblu92
tblu92's Avatar
St. Jude Donor '13-'14-'15
Unlikely the tach would go crazy with a failed speed sensor---Sound like you may have a voltage or ground issue---How fresh is your battery ? Is your alternator charging ?
I would look here 1st----Also try disconnecting the battery over night to unload any glitches in your ECM/BCM that may be a result of a low or high voltage issue
Old 07-27-2015, 02:43 PM
mrx_33k
mrx_33k's Avatar
That's what we initially thought as well. We took all the ground connection and connected each one individually to a solid post at the appropriate locations. Which r like 25 locations. Its a new battery and alternator was changed last year.
Old 08-03-2015, 09:17 PM
mrx_33k
mrx_33k's Avatar
Well it ended up being the vss (vehicle speed sensor) . it took me 5 mins to change it. Cleard the codes and its been running perfect now.
Old 08-03-2015, 09:19 PM
mrx_33k
mrx_33k's Avatar
Old vss and new vss.
Old 08-04-2015, 06:42 AM
dadaroo
dadaroo's Avatar
The VSS has no input/interaction to the Tach. Anyone care to try and explain that one.
Old 08-04-2015, 09:39 PM
mrx_33k
mrx_33k's Avatar
Well guys it lasted all of two says. Its doing it again. These are the codes its giving me. B0367, B0516, U1176, P0103, P1676, B0332, B0337, B0361, B0441. Any ideas?
Old 08-05-2015, 06:54 AM
dadaroo
dadaroo's Avatar
Can you delete those and then pull them again when the IPC acts up again? Not sure how old they are. Thanks.
Also, I don't see P1676 in my FSM.
Old 08-05-2015, 09:40 AM
mrx_33k
mrx_33k's Avatar
Sorry it was P1626. Yes after I clear them they pop up again after a day of driving.
Old 08-06-2015, 06:17 AM
dadaroo
dadaroo's Avatar
Only B0516 is related to your issues. Here are the diagnostics. I just posted 2001 since you didn't tell us what year. I doubt it changes from the other years.
https://www.dropbox.com/s/0se90pkaq0...stics.pdf?dl=0
You may be having an issue with the IPC.
To My Tach and Speedo going crazy
Quick Reply: My Tach and Speedo going crazy
