P2135 hp tuner disable
This weekend at the track, got engine reduce power and bang, nothing on the pedal. Safe mode
Retreived the code
Find p2135
If we disable the code with hp tuners, will this prevent the car to fall in safemode ??
Retreived the code
Find p2135
That code is usually a TB (drive by wire) problem. When you depress the accelerator pedal you are pushing down on a sensor indicating the desired amount of throttle opening, which is sent to the PCM. The PCM sends a voltage to the TB to open the throttle plate. The two sensors in the plate convert the amount of opening to a voltage which is sent back to the PCM. When these two voltage are the same everything works normally, however if there is a difference in the voltage for more than 2 seconds the P2135 code is set. Then everything usually shuts off and the check engine light comes on. Usually a problem in the TB or accelerator pedal assmebly. You need to have it check out for the source of the trouble.
When you depress the accelerator pedal you are pushing down on a sensor indicating the desired amount of throttle opening which is sent to the engine management computer. In response the computer sends a voltage to the electric motor to open the throttle plate. Two throttle position sensors imbedded in the throttle body convert the amount of throttle opening to a voltage signal to the computer.
Read more at: http://www.obd-codes.com/p2135
Copyright OBD-Codes.com
St. Jude Donor '13-'14-'15
I don't see a P2135 anywhere --are you sure this is correct ??? What year is your car ?
OK I found the code on a C6 car It is T-Body related
Most all T-Body codes EVEN if deleted with tuning will not prevent the car going into reduced power mode----I know many fixes for T-Body codes but need to know more about all the mods on tour car-
