anyone help with a baseline tune
2002 Stock bottom end ls1, 243 heads stage 2 TEA ported heads, 231/238 .615/618 112+3 cam, fast 92 intake, Ls2 throttle body, 1 7/8 AR headers an x pipe, corsa mufflers, 42# ls3 injector .
I'm having hell with it getting to startup without using the pedal after startup I can get it to idle with a little throttle play but still not even 50% right yet.
These are very very broad strokes of the tuning brush, but given that you sound pretty new I'll generalize. A lot. Make sure you are in Imperial format, so Tools -> Options -> Imperial.
Make sure you have your injector data correct. The Flow Rate vs KPA is the most important, but the more info you get correct the better.
Flow Rate vs KPA
Offset vs Volts vs VAC
Short Pulse Adder
After you copy and paste those into your injector tables, change your format back to Metric from Imperial and input the following table into your Idle -> Airflow -> Base Running Airflow -> Idle Airflow.
Then go to Airflow -> General -> Main VE -> Primary
If it's an auto you'll need to raise your idle to at least 800rpm, but this should get you started.
Flow Rate vs KPA
Code:
41.7293725641814 42.0393976203788 42.3494226765763 42.6594477327738 42.9694727889713 43.2794978451688 43.5275178901268 43.8375429463242 44.0855629912822 44.2715780250007 44.4575930587192 44.6436080924377 44.8296231261562 45.0156381598747 45.2636582048327 45.4496732385512 45.6976932835092
Code:
14.0077821011673 14.0383001449607 14.0383001449607 14.0535591668574 14.0688181887541 14.0840772106508 14.0993362325475 14.0993362325475 14.1145952544442 14.1145952544442 14.1145952544442 14.1298542763409 14.1298542763409 14.1451132982376 14.1603723201343 14.1603723201343 14.175631342031 14.0077821011673 14.0383001449607 14.0383001449607 14.0535591668574 14.0688181887541 14.0840772106508 14.0993362325475 14.0993362325475 14.1145952544442 14.1145952544442 14.1145952544442 14.1298542763409 14.1298542763409 14.1451132982376 14.1603723201343 14.1603723201343 14.175631342031 10.605020218204 10.6355382619974 10.6355382619974 10.6507972838941 10.6660563057908 10.6813153276875 10.6965743495842 10.6965743495842 10.7118333714809 10.7118333714809 10.7270923933776 10.7270923933776 10.7270923933776 10.7423514152743 10.757610437171 10.7728694590677 10.7881284809644 7.21751735713741 7.2327763790341 7.2480354009308 7.2632944228275 7.27855344472419 7.27855344472419 7.29381246662089 7.30907148851759 7.32433051041428 7.32433051041428 7.32433051041428 7.33958953231098 7.33958953231098 7.33958953231098 7.35484855420768 7.37010757610437 7.38536659800107 5.03547722590982 5.05073624780652 5.06599526970321 5.08125429159991 5.09651331349661 5.09651331349661 5.1117723353933 5.12703135729 5.12703135729 5.14229037918669 5.14229037918669 5.15754940108339 5.15754940108339 5.15754940108339 5.17280842298009 5.18806744487678 5.20332646677348 2.83817807278553 2.86869611657893 2.88395513847562 2.88395513847562 2.91447318226902 2.91447318226902 2.92973220416571 2.94499122606241 2.96025024795911 2.96025024795911 2.96025024795911 2.9755092698558 2.9755092698558 2.9907682917525 3.0060273136492 3.0060273136492 3.02128633554589 2.44144350347143 2.47196154726482 2.47196154726482 2.48722056916152 2.50247959105821 2.51773861295491 2.53299763485161 2.53299763485161 2.5482566567483 2.5482566567483 2.563515678645 2.563515678645 2.563515678645 2.5787747005417 2.59403372243839 2.59403372243839 2.62455176623178 2.04470893415732 2.05996795605402 2.07522697795071 2.09048599984741 2.10574502174411 2.10574502174411 2.1210040436408 2.1362630655375 2.1515220874342 2.1515220874342 2.1515220874342 2.16678110933089 2.16678110933089 2.16678110933089 2.18204013122759 2.19729915312428 2.21255817502098 1.81582360570687 1.84634164950027 1.84634164950027 1.86160067139696 1.87685969329366 1.89211871519036 1.90737773708705 1.90737773708705 1.92263675898375 1.92263675898375 1.93789578088045 1.93789578088045 1.93789578088045 1.95315480277714 1.96841382467384 1.98367284657053 1.99893186846723 1.58693827725643 1.61745632104982 1.63271534294652 1.64797436484321 1.66323338673991 1.66323338673991 1.67849240863661 1.6937514305333 1.70901045243 1.70901045243 1.70901045243 1.7242694743267 1.7242694743267 1.7242694743267 1.73952849622339 1.75478751812009 1.77004654001679 1.44960708018616 1.46486610208286 1.48012512397955 1.49538414587625 1.51064316777295 1.51064316777295 1.52590218966964 1.54116121156634 1.55642023346304 1.55642023346304 1.55642023346304 1.57167925535973 1.57167925535973 1.57167925535973 1.58693827725643 1.60219729915312 1.61745632104982 1.2970168612192 1.32753490501259 1.32753490501259 1.34279392690929 1.35805294880598 1.37331197070268 1.38857099259937 1.38857099259937 1.40383001449607 1.41908903639277 1.41908903639277 1.41908903639277 1.41908903639277 1.43434805828946 1.44960708018616 1.44960708018616 1.46486610208286 1.19020370794232 1.20546272983902 1.22072175173571 1.23598077363241 1.25123979552911 1.25123979552911 1.2664988174258 1.2817578393225 1.2970168612192 1.31227588311589 1.31227588311589 1.31227588311589 1.31227588311589 1.32753490501259 1.34279392690929 1.34279392690929 1.35805294880598 1.08339055466545 1.09864957656214 1.11390859845884 1.12916762035554 1.14442664225223 1.14442664225223 1.15968566414893 1.17494468604562 1.19020370794232 1.19020370794232 1.19020370794232 1.20546272983902 1.20546272983902 1.22072175173571 1.23598077363241 1.23598077363241 1.25123979552911 1.00709544518196 1.02235446707866 1.03761348897536 1.05287251087205 1.06813153276875 1.06813153276875 1.08339055466545 1.09864957656214 1.09864957656214 1.11390859845884 1.11390859845884 1.12916762035554 1.12916762035554 1.12916762035554 1.14442664225223 1.15968566414893 1.17494468604562 0.915541313801785 0.930800335698482 0.946059357595178 0.961318379491875 0.991836423285267 0.991836423285267 1.00709544518196 1.00709544518196 1.02235446707866 1.03761348897536 1.03761348897536 1.03761348897536 1.03761348897536 1.05287251087205 1.06813153276875 1.06813153276875 1.08339055466545 0.854505226215 0.869764248111696 0.885023270008393 0.900282291905089 0.915541313801785 0.930800335698482 0.930800335698482 0.946059357595178 0.961318379491875 0.961318379491875 0.961318379491875 0.976577401388571 0.976577401388571 0.991836423285267 1.00709544518196 1.00709544518196 1.03761348897536 0.793469138628214 0.823987182421607 0.823987182421607 0.839246204318303 0.854505226215 0.854505226215 0.869764248111696 0.885023270008393 0.900282291905089 0.900282291905089 0.900282291905089 0.915541313801785 0.915541313801785 0.930800335698482 0.946059357595178 0.946059357595178 0.961318379491875 0.732433051041428 0.762951094834821 0.762951094834821 0.778210116731518 0.793469138628214 0.80872816052491 0.823987182421607 0.823987182421607 0.839246204318303 0.839246204318303 0.839246204318303 0.854505226215 0.854505226215 0.869764248111696 0.885023270008393 0.885023270008393 0.900282291905089 0.671396963454643 0.701915007248035 0.701915007248035 0.717174029144732 0.732433051041428 0.747692072938125 0.762951094834821 0.762951094834821 0.778210116731518 0.778210116731518 0.793469138628214 0.793469138628214 0.793469138628214 0.80872816052491 0.823987182421607 0.823987182421607 0.839246204318303 0.625619897764553 0.656137941557946 0.671396963454643 0.686655985351339 0.701915007248035 0.701915007248035 0.717174029144732 0.732433051041428 0.732433051041428 0.747692072938125 0.747692072938125 0.762951094834821 0.762951094834821 0.762951094834821 0.778210116731518 0.793469138628214 0.80872816052491 0.59510185397116 0.610360875867857 0.625619897764553 0.64087891966125 0.656137941557946 0.671396963454643 0.686655985351339 0.686655985351339 0.701915007248035 0.701915007248035 0.717174029144732 0.717174029144732 0.717174029144732 0.732433051041428 0.747692072938125 0.747692072938125 0.762951094834821 0.549324788281071 0.579842832074464 0.579842832074464 0.59510185397116 0.610360875867857 0.625619897764553 0.64087891966125 0.64087891966125 0.671396963454643 0.671396963454643 0.671396963454643 0.686655985351339 0.686655985351339 0.686655985351339 0.701915007248035 0.717174029144732 0.732433051041428 0.518806744487678 0.534065766384375 0.549324788281071 0.564583810177768 0.579842832074464 0.579842832074464 0.59510185397116 0.610360875867857 0.625619897764553 0.625619897764553 0.625619897764553 0.64087891966125 0.64087891966125 0.64087891966125 0.671396963454643 0.671396963454643 0.686655985351339 0.488288700694286 0.503547722590982 0.518806744487678 0.534065766384375 0.549324788281071 0.549324788281071 0.564583810177768 0.579842832074464 0.579842832074464 0.59510185397116 0.59510185397116 0.610360875867857 0.610360875867857 0.610360875867857 0.625619897764553 0.64087891966125 0.656137941557946 0.442511635004196 0.473029678797589 0.473029678797589 0.488288700694286 0.518806744487678 0.518806744487678 0.534065766384375 0.534065766384375 0.549324788281071 0.564583810177768 0.564583810177768 0.564583810177768 0.564583810177768 0.579842832074464 0.59510185397116 0.59510185397116 0.610360875867857 0.411993591210803 0.442511635004196 0.442511635004196 0.457770656900893 0.473029678797589 0.488288700694286 0.503547722590982 0.503547722590982 0.518806744487678 0.518806744487678 0.518806744487678 0.534065766384375 0.534065766384375 0.549324788281071 0.564583810177768 0.564583810177768 0.579842832074464 0.381475547417411 0.396734569314107 0.411993591210803 0.4272526131075 0.442511635004196 0.442511635004196 0.457770656900893 0.473029678797589 0.488288700694286 0.488288700694286 0.488288700694286 0.503547722590982 0.503547722590982 0.503547722590982 0.518806744487678 0.534065766384375 0.549324788281071
Code:
0.319148936170213 0.319148936170213 0.319148936170213 0.27355623100304 0.227963525835866 0.182370820668693 0.151975683890578 0.106382978723404 0.0911854103343465 0.060790273556231 0.0303951367781155 0.0151975683890578 0 -0.0151975683890578 -0.0303951367781155 -0.0303951367781155 -0.0455927051671733 -0.0455927051671733 -0.0455927051671733 -0.060790273556231 -0.060790273556231 -0.060790273556231 -0.060790273556231 -0.060790273556231 -0.060790273556231 -0.060790273556231 -0.060790273556231 -0.0455927051671733 -0.0455927051671733 -0.0455927051671733 -0.0455927051671733 -0.0455927051671733 -0.0455927051671733 -0.0455927051671733 -0.0455927051671733 -0.0455927051671733 -0.0455927051671733 -0.0303951367781155 -0.0303951367781155 -0.0303951367781155 -0.0303951367781155 -0.0303951367781155 -0.0303951367781155 -0.0303951367781155 -0.0303951367781155 -0.0303951367781155 -0.0303951367781155 -0.0303951367781155 -0.0303951367781155 -0.0303951367781155 -0.0303951367781155 -0.0151975683890578 -0.0151975683890578 -0.0151975683890578 -0.0151975683890578 -0.0151975683890578 0 0 0 0 0 0 0 0 0 0 0
Code:
28 26.888671875 25.33984375 22 14 13 11.25 11.25 11.25 11.25 28 26.572265625 25.2353515625 22.7490234375 14 12.7998046875 10.75 10.75 10.75 10.75
Code:
25.1473645389337 27.9978214765962 30.4998892329888 33.247413003458 37.9981745662288 41.5849995461208 45.1639065900749 48.7507315699669 52.3296386139209 55.9164635938129 56.0035608891303 57.6979991798519 59.4003554065115 59.4003554065115 59.4003554065115 59.4003554065115 59.4003554065115 59.4003554065115 59.4003554065115 59.4003554065115 25.0444313717403 27.9978214765962 30.9987191970798 32.9544493737538 38.3861534271884 43.9682982634442 49.5504430996999 55.1246700000177 60.7068148362735 66.2889596725292 70.3746146165121 72.837092693215 74.6265462151921 74.9986892042758 74.9986892042758 74.9986892042758 74.9986892042758 74.9986892042758 74.9986892042758 74.0010292760939 25.5511792717692 27.9978214765962 30.9987191970798 33.8333402628664 39.6213514335089 46.1457306463808 52.6701098592528 59.2024070080627 65.7267862209347 72.2511654338066 75.7984007340089 79.203113187328 81.7922782390381 82.3306978828188 82.3306978828188 82.3306978828188 82.3306978828188 82.3306978828188 82.3306978828188 81.9981445734248 25.9470760686668 27.538581192195 31.9647073815099 35.9553470942374 42.0838295102118 48.7111418902771 55.3384542703424 61.9578487144698 68.5851610945351 75.2124734746005 78.7992984544925 82.1960929718736 85.4978722579994 85.4978722579994 85.4978722579994 85.4978722579994 85.4978722579994 85.4978722579994 85.4978722579994 85.4978722579994 26.3508908015023 29.5418189844967 34.1896473800742 40.0014123585305 47.0008677276796 53.1847756952196 59.3607657268217 65.5446736943618 71.7206637259639 77.904571693504 81.4993146093339 84.6981607282663 87.3348333956041 87.999940014392 87.999940014392 87.999940014392 87.999940014392 87.999940014392 87.999940014392 87.999940014392 27.871134501589 30.6028224001822 37.000514638047 45.4568702197791 53.0026631686468 58.67190530022 64.3332294958552 70.0024716274284 75.6637958230637 81.3330379546369 85.3711852829921 86.701398520568 89.3301532519678 90.0031778066937 90.0031778066937 90.0031778066937 90.0031778066937 90.0031778066937 90.0031778066937 90.0031778066937 29.4863934329311 33.5403766331622 40.0014123585305 49.1703821746783 56.0035608891303 61.443182878503 66.8828048678756 72.3303447931862 77.7699667825588 83.2095887719314 85.877933183021 88.6254569534902 91.4996676989665 91.4996676989665 91.4996676989665 91.4996676989665 91.4996676989665 91.4996676989665 91.4996676989665 91.753041648981 30.9987191970798 35.6227937848434 42.6301670899304 51.9970853045269 57.9988807454941 63.2009646567282 68.4030485679622 73.5972145432584 78.7992984544925 84.0013823657265 88.6967183769317 91.9984976630575 94.5005654194501 95.4032101163766 95.4032101163766 95.4032101163766 95.4032101163766 95.4032101163766 95.4032101163766 95.4032101163766 32.3764400502833 37.6656212568349 46.0032077994977 54.3724660859124 60.2950821675 65.3863149756028 70.4775477837055 75.5687805918083 80.660013399911 85.7512462080138 92.402312395893 95.7991069132741 98.4991230681156 99.2038193665932 99.2038193665932 98.3645181571704 97.5252169477475 95.8545324648398 95.7595172335844 95.8545324648398 33.7620788394248 39.6688590491366 47.9985276558615 57.207087151699 63.2880619520456 68.1892642976376 73.0904666432295 77.9837510528835 82.8849533984754 87.7861557440673 94.8727084085338 98.4991230681156 100.45485324479 102.497680716781 102.497680716781 100.953683208881 99.40968570098 96.313772749241 96.1158243507922 96.313772749241 35.1477176285663 41.8304555601973 51.498255340436 60.0021185377958 66.003913978763 70.7467576055959 75.4896012324288 80.2324448592617 84.9752884860946 89.7181321129274 96.4167059164344 100.399427693224 102.497680716781 103.899155377798 103.899155377798 102.117619791759 100.33608420572 96.7650950977042 96.480049403938 96.7650950977042 36.5254384817699 43.999970007196 54.4595633812298 62.9159189629619 67.460814191346 72.6628981025801 77.8728999497521 83.0749838609862 88.2849857081582 91.8955644958641 97.6994115383825 101.199139222957 103.455750965273 104.698866907532 104.698866907532 102.830234026175 100.961601144818 97.5727245633753 97.3589402930506 97.2243353821054 38.1090256693602 46.5812171229682 57.1674974720092 65.1250230896504 68.9968937633086 74.0168651479698 79.028918596693 84.0488899813543 89.0609434300775 94.0809148147387 98.4991230681156 101.99885075269 104.461328829393 105.498578437265 104.960158793484 103.00442861681 101.048698440136 98.3882719649843 98.2457491181011 97.6756577305686 39.1541932131697 47.5234514995844 58.996540673676 67.0015739069449 71.2851772493766 76.0913643637131 80.8896335421116 85.6958206564481 90.4940898348467 95.3002769491832 99.2988345978487 102.798562282423 105.419399077885 106.298289966998 105.569839860706 103.527012388715 101.484184916723 99.1959014306553 99.1246400072137 98.1348980149698 40.3181297960486 48.9961875840433 60.3663435909416 68.7118480695424 73.003369347912 77.6195259997377 82.2436005875013 86.859757239327 91.4838318270906 96.0999884789163 100.098546127582 103.598273812156 106.32996171075 107.098001496731 105.949900785728 103.819976018419 101.69005125111 100.003530896326 100.003530896326 98.586220363433 41.4979022508034 50.4768416044403 61.1264654409849 70.0024716274284 75.4183398089872 79.7177790232948 84.0093003016645 88.3087395159721 92.6002607943418 96.8997000086494 100.898257657315 104.002088544992 106.456648685757 107.098001496731 106.013244273231 104.002088544992 101.452513172971 100.003530896326 100.003530896326 99.0454606478342 44.4592102915972 51.9495776888992 61.8945052269662 71.1664082103073 77.9995869247594 82.0773239328043 86.1550609408493 90.2407158848322 94.3184528928772 98.3961899009222 102.402665485526 105.419399077885 107.462226549877 107.462226549877 106.076587760735 104.002088544992 101.484184916723 100.003530896326 100.003530896326 99.4967829962974 46.5020377635886 54.0003230968286 62.6546270770095 71.8315148290952 79.4168974576527 83.5342241453874 87.6515508331221 91.7688775208569 95.8862042085916 100.003530896326 104.002088544992 106.496238365446 107.002986265475 108.459886478058 106.139931248239 103.819976018419 101.500020788599 100.003530896326 100.003530896326 99.1800655587794 48.236065734 54.9029677937551 63.4226668629908 71.9502838681645 80.4779008733382 84.3814432907482 88.2849857081582 92.1964460615062 96.0999884789163 100.003530896326 104.002088544992 106.496238365446 107.002986265475 108.246102207734 105.98157252948 103.717042851226 101.444595237034 100.003530896326 100.003530896326 99.1800655587794
I've got it running the issue I'm having is with the idle hanging on decelI can't get that issue cleared up. I've been tuning for awhile just have never messed with going to a larger size throttle body with a dbw setup an it has me head scratching. Sorry I should have been more clear an not made it look like I was looming for a complete tune but more of a baseline for the throttle body.
St. Jude Donor '13-'14-'15
To fix a hanging idle in gear---1st see if it happens at ANY MPH or only in a specific MPH range-- and in all the gears or only 1 or 2
That way you an make specific changes only where needed
The most common area is in 1st gear from 0 -6 MPH---
To correct a hanging idle you need to ADD more % to the
"throttle follower decay rate in gear " Leave the DELAY rate alone
PS: If any of the table boxes have a "0" entered -- input the last table number that has a number so none of the boxes have a "0"
( you can't add a % to "0" )
ALSO : On some large cammed engines you should also delete the DFCO program to eliminate the fuel cut-off on decal which will cause it to stumble or die at a stop
