C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Flex fuel sensor pin?
Old 11-24-2015, 06:07 PM
corvettekaan
8th Gear
corvettekaan's Avatar
Default Flex fuel sensor pin?
I have problem help me
I have 2000 year corvette c5.which has ls1 pcm. I want to connect flex fuel unit(zetronix). Does anybody know pin number and diagram.pcm number 09354896 please help flex fuel sensor pin (71) or?
Old 11-25-2015, 09:44 PM
SMOKINV8
SMOKINV8's Avatar
Blue connector, pin 56.
Old 12-04-2015, 01:11 PM
romandian
romandian's Avatar
interesting. what does that pin do? mange mixture?
Old 12-07-2015, 08:10 PM
HardcoreABN
HardcoreABN's Avatar
I didn't think the C5 PCMs were flex fuel capable
Old 12-22-2015, 10:45 PM
The Highlander
The Highlander's Avatar
You can swap to an 04 ECu
There is one oS for the 0411 ECU that is actually flex fuel compatible... but good luck making it work for your vette.
To Flex fuel sensor pin?
Quick Reply: Flex fuel sensor pin?
