Weird dip in dyno graph/cut out
Well, the Cylinder Air looks pretty flat leading up to the lean spike.
There may still be a problem with the Injector calibration but there looks to be a problem related to the calculation of the Cylinder Air. VE table or something related to the way the PCM calculates Cylinder Air.
Received 1,194 Likes
St. Jude Donor '15
It's in MAF only but that's something else I'd change too...
I'd increase MAF and VE tables in that spot by a significant amount, say 6-8%, just to see if it responds like it should as a first step
Could also just do some PE "raping" and increase fueling that way just as a test. Obviously don't leave it that way, but it'd be interesting to see what it does.
Thanks for posting the screen shots
I'm just a tad over 600rw & have tried several sets of injectors(not the posted) including ID 1000's, FIC, LS3/7 & LS9. The only issue I ever had was the sudden fuel run out with LS3/7 & some drive-ability concerns with the FIC & LS9. My goal has been to get a higher IDC 80% plus. Currently deatschwerks injectors, I believe 43lbs with good results. LS9's are inexpensive, good data just to try if their is a suspicion.
I do remember a similar problem to this 2 or 3 years back. My cam was 17* of overlap & I was struggling with some manners. Speaking with a couple of different tuners trying different files & something like this issue showed. I'm going to say it showed out of nowhere & most likely was a bug or glitch in one of the files that had been sent to me.
We backed up into one of my own previous files, did an "entire rewrite" & as mysteriously as it appeared, it disappeared. This would be my very first suggestion.....easy to try. You just need a previous known good file.
My question would be as it is, what happens if you keep the motor just below PE & drive thru that 3500rpm area? Or is it a PE only issue?
As well easy to try would be swapping banks, I would do injectors & ignition just to see if the problem moves.
What a nightmare problem fun though when it's solved.
St. Jude Donor '15
Lean spot happens on both banks but is worse on one side. Without a wideband on both banks I'm not really sure how different they are. NB O2's are so sensitive around stoich it doesn't take much to get them to swing from ~700mv to 200'ish
Your comments about the KR make wonder if the tuner tried a blanket removal of 5 or 6* in the higher load area just to see if there is any connection.
If you swap and the data flips banks are you any closer to solving the problem?
St. Jude Donor '13-'14-'15
Sorry, been at work all day. 12's as normal, so I only have a couple of evening hours before I do it all again.
A wide band was hooked up but the lean spike was noticed by the car's reaction in person, but looking at the log, the Bank 2 front O2 sensor voltage TANKS down to 43mV at it's worst, seemingly out of nowhere. Bear in mind I'm new to HP Tuners so I'm probably missing a critical graph or chart somewhere. 10:33:55:9xx is when the event happens in the log. You can see the passenger side go really lean and hang low for a few ticks in the log before recovering, coinciding with the dip in the dyno graph.
I'm uploading the log to google drive, will post a link momentarily.
Try this: https://drive.google.com/open?id=0Bz...Vk2SGxNMzFSblE
When your engine is in power enrichment you cannot use the stock narowband readings as an indication of AFR ratios as the naroowband 02's are not being used at all to command your AFR ratio and are turned OFF---any readings you get of 02 voltages are by accident
To get proper accurate wideband readings with your data logger you must select a PID the incorporates your brand of wideband and wire it into your tuner correctly on the proper wire leads as instructed by the manufacturer
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I Believe In The Beer Fairy
If you are looking at 02 voltages from your data logger most likely thry are from your stock narrowband 02 readings and NOT your wideband readings---
St. Jude Donor '15
Ignore him.
