When dino tuning do you deactivate active handling?
Mine doesn't appear to be working. No codes, no comms errors on DIC. I had the car dyno tuned. I am just wondering if it was possibly turned off.
St. Jude Donor '13-'14-'15
Don't quite understand what your issue is ?? Are you saying when dyno tuned the numbers were low ?
Yes -----when on the dyno you must turn off the TC and active handling However you should still get a DTC or ABS message as on the dyno as the front wheels are stationary and that will light up your dash with messages---But this is common--just ignore them--
After tune no active handling when driving.
I don't believe that TUNING can deactivate your Active Handing system
As far as I know A/H only prevents the car from pitching sideways on a hard launch but only when the car is pointed straight----I do not think it has any affect on handling when the car is turning or in the process of a circular burnout----At least on my car it has no affect other than keeping the car going straight on a straight launch
