After Tune MPG calculations are incorrect
I have a 2000 FRC I installed a cam, 36lb injectors, 243 heads, 1 3/4 headers, CAI, and so on and after I got it running and tuned I noticed that my MPG calculations are incorrect. I verified that the actual MPG is much less than what is being displayed by the on board computer. Computer showing 35 MPG, actuality its 28 MPG.
I assume this is a result of the larger injectors. My question is: Is there a way to correct the calculation used for the MPG? I'm using HP Tuners.
Thanks for any Help/ideas, I 'm sure someone else that has made these mods has probably seen the same behavior in the past.
Thanks.
Thanks.
Thanks for taking the time to try and help me, I do appreciate it.
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,084 Likes
Doug, the injector data was updated to reflect the new injectors as the tune was adjusted. I thought that would have covered it, is there somewhere else/a particular field I can look at in HP tuners to adjust that fuel flow rate?
Most injectors are rated at 45lbs (3 bar) fuel pressure while your car runs at 58 (4 bar) So the data is skewed.
