Intake
Intake
I have a 2001 base, saving up over winter for some upgrades. I understand he 2001 came with ls6 intake? is this correct? is there a way to tell? thanks
St. Jude Donor '13-'14-'15
The LS6 intake has a flat bottom underside where the LS1 has more of a V-shape underside
Also the LS6 has a differently routed PCV system-----The PCV valve is mounted on the front of the engine on the pass side----The LS1 intake has the PCV valve mounted on the driver side valve cover----near the firewall
