Any hand held tuners that would perform
Hello folks , I have a 98 6 spd with a Maggie MP112, upgraded Lingenfelter fuel pump, full exhaust , upgraded valve springs , cooling and fans, throttle body, Blackwing,
Are there any hand held tuners that I could use to tweek my existing tune, such as Fuel/air etc , I do believe its running a little rich (exhaust smell) .
Just my opinion the only hand held I would trust with a 98 is the Chuck Cow. He is a supporting vendor on this forum.
Supporting Vendor
no.. you'd want to take that setup to a shop and get it done on a dyno... not with a handheld..
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS LS3, short-throw shifter, NPP perf. exhaust, BMR strut-tower brace, Cold Air Inductions cold air intake, catch-can, ported/polished TB, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Regardless of what you read.....
It works very well just so long as your car is built right and road-worthy.
Sadly, too many people believe their vehicles are road worthy and they are not.
That's the only time my package won't work.
Chuck CoW
Regardless of what you read..... We have the only wideband remote tuning package.
Chuck CoW
Chuck CoW
St. Jude Donor '13-'14-'15
You need to use full tuning software--either HP tuners or EFILIVE----
With a boosted setup most always the kit comes with larger injectors---So you need software that can change the injector flow rate---
A mail order tune can work as long as they have HP or EFLIVE
However it still takes some dyno time or WOT street driving using a wideband to get the fuel and timing spot on and SAFE----A mailorder tune is just their "best guess" and can be sometimes perfect-- but most often just a starting point---
I always recommend to someone that adds boost to get the base tuning software from the manufacturer of the supercharger---They have the best experience of tuning for their products---PLUS if the KIT is NEW----they will fully warranty the kit only if you have used their tuning---If you used someone else--or did your own tuning--they will always blame the tune for ANY failures that may occur----
Thanks for the input folks , I just thought there might of been a new fandangled hand held with more adjustable perimeters these days with technology and such.
