C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Failing the MAF for VE Tuning
Old 03-24-2017, 06:26 PM
MSUGTO
MSUGTO's Avatar
Default Failing the MAF for VE Tuning
I've been trying to find out how to fail the MAF so that I can tune my VE table and for the life of me I can't find any table relating to MAF failure limits under the airflow tab and there's not a airflow tab under the engine diagnostics table either. The car is a 2002 Z06 and below are a few screen shots of what I'm seeing in HP Tuners, any help would be appreciated, thanks.
Old 03-24-2017, 07:08 PM
RedRiderZR1
RedRiderZR1's Avatar
looks like your interface is in basic mode. Need to put it into advanced.
Old 03-24-2017, 07:11 PM
MSUGTO
MSUGTO's Avatar
Yep that did it, been a while since I've used it. Thanks!
Old 03-26-2017, 12:58 AM
tblu92
tblu92's Avatar
St. Jude Donor '13-'14-'15
In order to do SD tuning you must dis able the MAF reporting otherwise you will put the car into a reduced power mode and the timing will run in the low octane table only
To dis able the MAF the proper table is in the "diagnostics section" of your tune You have to set the fail frequencies to the max and min values so the MAF does not report---Also we were taught at EFILIVE to copy the Hi Oct spark table and paste it into the Low oct table so the timing isn't altered-
Old 03-26-2017, 05:47 PM
Joshboody
Joshboody's Avatar
I just did this and discovered knock learn factor gets stuck at 0 once you're done. So have to keep high low tables equal for a bit before it gets back to 1. Not sure if there's a way to prevent this.
To Failing the MAF for VE Tuning
Quick Reply: Failing the MAF for VE Tuning
