What is burst knock?
Re: What is burst knock? (CrazyMagMan)
This should help.
4.1.8 Burst Knock
This section is tables that reduce timing on Tip-in.
4.1.8.1 Delta Airflow to Enable
Change in Airflow that initiates Burst Knock. If the change in air per cylinder exceeds this value, Burst knock will be added.
4.1.8.2 Tip-In Max KR
This table limits the maximum knock retard due to throttle Tip-in
4.1.8 Burst Knock
