Help with H-pipe removal
I'm replacing the H-pipe section on my 03 Z06 with a Bassani x-pipe. When I remove the h-pipe do the cats remain on the car or do they come off with the h-pipe???
Thanks,
Greg
Thanks,
Greg
The instructions for the TPIS headers say this is a two person job but I did just fine by myself. The mid section isn't that heavy. Just put a few blocks of wood under there so when you pull it loose it doesn't drop and land on your toe or something. Of course, it would have been a lot easier with help but none was available at the moment.
Originally Posted by SpiralCoupe
So, what do you do when you want to put in an aftermarket x-pipe? The x-pipe is a small piece.
Originally Posted by 400hp
You cut off the X pipe at the appropriate legnth and install the X pipe.
