Painting Rotor Hats
I would say clean 'em up or scuff them with fine steel wool and apint with high heat paint..no experience with this just off the top of my head..
SE Ohio Event Coordinator
CI-V Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Curise-In V Veteran
Cruise-In VI Veteran
Make a template out of thin cardboard or poster board. Make sure the hole fits tightly around the hat, tape it down and have at it.
I painted my hat. I used masking tape and tore off small amounts of tape about 2" long or so and went around in a circle the best I could. High temp paint from NAPA worked fine. Put on about 3 coats. You can use a little acetone to remove any overspray, but don't worry, the pads will remove anything anyway. My job looks good and I've had the rotors on for about 2.5 months, no problems. Enjoy!
