Formula for converting RWHP to crank HP
I have a 99 A4 (3.15) that on the dyno ran 299 rwhp and 312 rwhp torque. How do I convert this to crank HP. I think I have to multiply by 0.15 or 0.18 its different on Manual transmissions due to less drivetrain power loss. The motor made 345 crank HP and 350 crank hp stock (factory rating). Thanks for the help. And yes there was a thread on this moons ago but I can't find it using the search.. Thanks
Originally Posted by TT_Vert
hes trying to find crank HP from RWHP. If you divide 299 by .82 you come out to 245 HP. You multiply by 1.18 299 RWHP = 353 crank HP.
Dave
Dave
You may want to check your math,
Cruise-In II Veteran
Cruise-In III Veteran
Originally Posted by allanlaw
Multiply by 1.18 and you'd be there.
You cant simply add back the percentage lost to the end result. You have to take the inverse proportion.
correct:
299 rwhp divided by .82 = 364.63 crank HP
incorrect
299 X 1.18 = 352.82
Originally Posted by kewlbrz
Thats incorrect (assuming 18%) is the loss from the crank to the rear wheels.
correct:
incorrect
299 X 1.18 = 352.82
correct:
incorrect
299 X 1.18 = 352.82
Tom
Most people use 15% loss for M6's, and 20% loss for A4's. This is just for bragging rights on HP so what does it matter but... some people believe 12% loss is more correct for M6's, and 18% loss for A4's. That would give a multiplication factor of .88 or .82 respectivly to get from rwhp to fwhp.
Originally Posted by AU N EGL
Manuals about 15% ?? So 400 RWHP be about 460 FLHP ?? That seems a bit high.
WHy do you say that.
If a stock m6 dynos on avg. 300 rwhp and you use 12% loss, that = 340 fwhp. Just about what the ls1 is rated.
When going from RWHP to FWHP you *divide* rather than multiply. For example:
If a given engine puts out 405hp at the flywheel, and the drivetrain "eats" 15% of that output, then the formula for calculating RWHP would be:
FWHP * .85 = RWHP (because RWHP is %85 of total flywheel output).
To get FWHP from RWHP, you just move the ".85" to the right-hand side of the equation by using Algebra and dividing both sides by ".85". This means that the left-hand side is left with FWHP and the right-hand side is RWHP / .85, such that:
FWHP = RWHP / .85
So using this formula for a car that dyno'd 350rwhp, and considering a 12% drivetrain loss for a manual transmission, equates to approximately 398fwhp (350 / .88).
FWHP = RWHP / .85
There is no formula, just a range. There are too many variables involved but you can get reasonably close. I had several friends who worked at the proving grounds when the 01 and 02 Z06 was developed. They reported less than +/- 2 hp on the engine dyno. from the reported 385 and 405. Different dyno's give different results i.e mustang dyno, etc.
Thanks for explaining this. It now makes sense to me. The guy who did my dyno test told me to multiply 299 X 1.18, which would not be correct because the 299 is the number showing the 18% powertrain loss. So instead of 299 x 1.18 = 352.82.. The actuall equation is 299(rwhp) / (divided) by .82 =364.6(fwhp). Thanks guys
