Just put in my order for a BIG Cartek 447CID and EXTRAS!
I first want to say thank you Mike (STEALTH) for your time and help in discussing your buildup and experiences with Cartek. That was awesome of you to take the time to talk to me about everything. Definitely a true Corvette enthusiast and I will be honored to hopefully race along side you some day soon!
And definitely.. thank you very much Dave and Cartek in advance for building me this awesome car. I'm extremely excited and have the utmost confidence in you and Julio and the rest of the team for building yet another (hopefully!) record breaking NA A4 C5!
Now, for everyone wondering here's the specs we've decided upon so far:
Cartek 447 X engine CNC machined, Callies 4.125 stroke crank, Diamond custom light weight pistons, Diamond full floating wrist pins, Darton MDS 4.155 sleeves, Molly ring set, Eagle 3D stroker rods 6.125 long, Clevite main and rod bearings, Rollmaster double roller timing chain, Ported ZO6 oil pump, Custom ground cam, custom Cometic head gaskets.
UPGRADES:
Vararam VR-B2 CAI
GHL Bullets
Stage 5X Heads
Fast 90MM intake ported to Stage 5 heads
NW 90MM throttle body
Flowed and matched set of 30# injectors
Comp Cams Type R Lifters
Kook’s 1 7/8 headers with off road pipes
ASP under drive pulley machined for clearance
Performance Transmissions Trans
Vigilante custom torque converter (probably 3500, not sure yet)
3.73 gears installed with drivers side HD output shaft
Cartek is going to be doing tuning on another car this week to decide what heads/cam will ultimately be the best and then we will go that route. So I'm waiting on them to post the specs on the final heads/cam choice. End result, yet another fully streetable, NA, A4, 9s C5!!
I also just put in my order yesterday to house of wheels for some 17x9.5 and 18x10.5 Chrome Z06 motorsport wheels and 275/40R17 & 305/35R18 Nitto 555RII tires for the street. Now if I actually have enough money leftover when this is done I hope to get a CCW drag package for the strip.
I'll only be getting a Wolfe 6-point roll bar and 5 point harnesses for now as I don't want to do the full cage until I'm CONSISTENTLY into the 9s.
Expect to see more updates as I have them. Target ETC is 4-6 weeks!
UPGRADES:
Vararam VR-B2 CAI
GHL Bullets
Stage 5X Heads
St. Jude Contributor
Hey....Mines an 03 E/B....maybe we should trade when you get it all done!
Man that sounds like it's gonna be a real BEAST
Good Luck and hope the wait doesn't kill ya
Sounds like a killer setup. The ONLY thing I would change is go with a set of LS7 heads and a custom sheetmetal intake. Those 2 mods are going to be worth their weight in gold on a big motor.
Phil
Phil
BWP,
Haha.. I said the same thing when my car was delivered with some guy's Lingenfelter Corvette in it. But the driver wouldn't give me that car.
Jake,
Umm.. I'm kind of :o to share the exact cost of everything. But since they do list their engine package prices on their site I'll just say this is somewhere between 20-40K.
Marco,
Yeah. Cartek is a great bunch of guys. I haven't had the luxury of meeting them face to face and seeing the shop yet but I'm real excited to do so soon! Lots of good things were said about them by previous customers so I am definitely excited. Ahhh! It's going to be a dream come true!
Jake,
Marco,
Phil
Phil
NCM, WSCC & SCC Member
Not a bad way to drop thirty large.
FYI, I would buy, stock 2002-2004 Z06 chrome wheels. They are about seven pounds lighter apiece than the others...The RII tires are great, almost perfect, imo.
I have researched the All-Pros and numerous other cylinder heads available for the LS1. What caught my eye about was the fact a box stock LS7 head they went almost 360cfm out of the box on a 4.125" bore. They also come with a larger 2.200" valve which is definitely needed on a big motor like your building. I would just hate to see your engine combo limited by the intake or cylinder head. Your building a nasty combo make sure you select all the right parts.
Phil
Phil
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Congratulations! I would like to make one suggestion though. Since you are doing so much I would add the DTE right side shaft, billet pinion support and brace. Just a suggestion.
1 Post
Cruise-In II Veteran
Cruise-In III Veteran
jdetar,
I wouldn't worry about head limitations (Phil97SVT), Dave & Julio are experts. I'd be careful about the sheet metal intake if you ever want to run in the American Super Car Challenge (http://www.rollingthunderz.com/racerules.html) as they're prohibited. You're going to need the CCW drag package for sure. I picked up my 382 from Cartek on Saturday; I put about 100 miles on it today running the stock wheels and tires; first and second gears are just about useless for anything other than granny starts. You'll have a bunch more torque too. Good luck.
UPGRADES:
Vararam VR-B2 CAI
GHL Bullets
Stage 5X Heads
UPGRADES:
Vararam VR-B2 CAI
GHL Bullets
Stage 5X Heads
I suspect that's my engine you're talking about. We should be at the "which head to use" stage right about now. I'm waiting with bated breath, as you can imagine.
Speed dog,
I guess so then! Keep us posted with how it goes. I'm curious to see the results. Cartek is always advancing themselves.
Thanks everyone else for the input. I'll talk to Dave about the other drivetrain upgrades. He didn't mention them before so maybe they're not necessary for the kind of power I'm doing. Maybe on NOS but NA doesn't seem to break stuff as much.
Speed dog,
A word about goals: while I'm building a new motor, I'm reusing some parts from my prior setup. My engine will have the setup you outlined, but with Lg LT's and 3" stuff rather than Kooks. I'm also running an MN6 rather than an AT. Finally, I'm NOT a straight line guy, but an old IMSA road racer: I'm looking for a real strong street car that can win the odd stop light grand prix that I come accross, but that is very capable of running the twisties either on a track or a nice mountain road. Drag setups and road setups are slightly different and may influence our cam/head choices, though I'll obviously take any power I can get
Looks like a great setup. One question: You will have 30# injectors on a 447 and I have 42# on a 427. Either yours are a little small or mine are a little big. Would be interested in your tuners thoughts on this issue. Thanks.
Speed dog,
Absolutely. Awesome to see you using your car for that. I wish I had tracks around here to do that sort of thing. If so I would be much more inclined to do that as that's more of what the Corvette was made for. Although I do plan on being pretty agressive with the street setup and possibly join in some local roadrace events every now and then. We're going to keep the cam profile reasonable enough where the car won't have to rough of an idle.
monstermouse,
Interesting! I can only assume yours are oversized or there is some other reason that I don't understand for doing that as I couldn't see why Cartek would suggest only 30# for this setup for me? How much power are you producing? I will have one of the guys post to this thread with some answers to cover the points mentioned. I pretty much let Cartek decide for me what was best to use for my goals as they're the experts. But from what I know an improperly tuned car will run lean on smaller injectors.
monstermouse,
jdetar,
Cartek & MTI both use #30 SVO's/#36 Dephi's on their big motors. I have a set of both. The Delphi's being on my 430 motor with a Walbro 255 pump.
#001 2001 Z06
#001 2001 Z06
