torque specs for spark plugs
Old 03-08-2005, 05:30 PM
2003silvercorvette
2003silvercorvette's Avatar
Default torque specs for spark plugs
well as the title says i need to know the torque specs for the spark plugs on our cars, thanks
Old 03-08-2005, 05:44 PM
ErnieN85
ErnieN85's Avatar
New 20nm
subsequent 15 NM
pretty low! also done with engine cold
Old 03-08-2005, 05:50 PM
Patches
Support Corvetteforum!
Patches's Avatar
Or 15 lb. ft. when heads are new and 11 l. ft. from then on.
Old 03-08-2005, 05:54 PM
RPOZ4Z
RPOZ4Z's Avatar
Cruise-In VII Veteran
also make sure you use antiseize compound on the plug threads.
Old 03-08-2005, 09:13 PM
66427-450's Avatar
now days, synthetic oil is recommended (over antiseize).... then torque to 10-11#
Old 03-08-2005, 09:44 PM
ErnieN85
ErnieN85's Avatar
So Who has a torque wrench that goes this low?
mine quits reading at 20 lbs
(3/8 drive craftsman)
Old 03-08-2005, 10:35 PM
Dan_the_C5_Man
Dan_the_C5_Man's Avatar
Exactly.. Tq wrenches are for cylinder head, rod and crank cap bolts, and larger suspension fasteners..
Just use anti-seize and snug 'em down nice and tight, don't lean on the wrench too much.
Old 03-08-2005, 11:43 PM
2KFRC5
2KFRC5's Avatar
I have 2, a Husky 3/8", and a Craftsman 3/8", and both go down to 10FtLbs on the shaft.
http://www.sears.com/sr/javasr/produ...44563000&cs=e1
Old 03-09-2005, 12:39 AM
Dan_the_C5_Man
The only time I've ever stripped a bolt (10mm case bolt on a bike motor) was using a Tq wrench.. Live and learn. I'll always trust my human touch over a Tq wrench at these low values.. Just my 2.5 cents.
Old 03-09-2005, 01:14 AM
larrysb
larrysb's Avatar
I have torque wrenches that go down to inch-lbs. Common for working on aluminum, particularly aircraft. But getting to be more common on cars with all the aluminum and lightweight alloys, magnesium and so on. It's more important for the light stuff to be torqued accurately. When a torque spec is 15 in-lbs, the line between too loose and too tight is very critical.
Old 03-09-2005, 09:16 AM
Steve-H
Steve-H's Avatar
torque them using a 3/8 ratchet holding it as close to the head as you can.
Old 03-09-2005, 09:41 AM
BlownV6
BlownV6's Avatar
People torque down spark plugs?
Old 03-09-2005, 12:50 PM
03LingenfelterC5
03LingenfelterC5's Avatar
here is a .pdf that has it all, including the plugs:
http://davidfarmerracing.com/C5torque.PDF
save it in your favorites folder...right?
To torque specs for spark plugs
Quick Reply: torque specs for spark plugs
