450 hp at rear?
450 hp at rear?
Just wanted to ask what it would take to get 450 rear wheel hp, normally aspirated and still be a daily driver? Car is going to Dallas tuner this spring/summer.
Originally Posted by 98stocker
How much that run you?
Cam - $450
AFR heads - $2100
LS6 intake - $500
Long tubes w/ cats/xpipe - $1850
CAI - $250
cat back - $800
double roller timing chain - $175
air bridge w/ smooth coupler - $150
pulley - $300
plugs and wires - $125
tune - $500
Install costs can vary quite a bit depending on where you have it done. Also didnt include gaskets, etc.. Getting the heads milled probably wouldnt be a bad idea either.
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
450 rwhp N/A is fairly simple and does not take a large cam at all. Can be done with a 224-228 cam. You will still have a very streetable car at 450 rwhp.
