Should this cam idle rough?
I have a 226 228 575 585 114 cam with stage 2.5 ls6 heads and my tuner/installer has my car idleing rough. By rough I mean it shakes the car noticably when in gear or park. I did not think this was that big of a cam. Also the sound it makes at idle is like the old muscle cars varum,varum,varum,varum. I don't have my hptuners yet but just wondering if this cam should be able to idle smooth.
I'm still learning but I would think that a 114 cam shouldn't have too much lope to it. I believe my G1 is on a 112 LSA and she has a little shake but nothing unbearable. I like when there are water droplets on the car because they shake in unison and it looks sweet!
Maybe the idle needs adjusting? What's RPM at idle?
I think I am idleing at 900rpm now. I just put in a 2800 vigalante t/c to help with the idle. I think the rough idle sounds good but just wondering if the car should shake like it does?
BTW, I have a Vigilante 2800 TC, too. The Vig2800 has nothing to do with the idle, unless I'm mistaken. The Vig2800 will help get you into & stay in the higher rpms when at WOT. Hope I explained that correctly.
I just went the other way, from a 114 LSA cam back to stock
I miss the way the car used to idle ....and sound
Originally Posted by Textralia
Well, your cam is actually a little smallish with all respect, however it is difficult to tune this size when using the MAF.
First check the basics, make sure all coils/wires/plugs connected and firing, all sensors plugged in, etc.
Originally Posted by rwj383
Exactly. Eliminating the MAF function then proper speed density tuning would do wonders. Its the only way I will tune now.
Interesting, are there negitives to SD tuning?
Do you turn the MAF funtion back on once SD tuning is complete?
Any How-To links explaining how to SD tune.
Originally Posted by Wt99C5
Textralia / rwj
BTW, when you run 8tb’s, mass air flow meters get a little expensive….
Textralia / rwj
SD certainly takes some understanding... Ask rwj, he knows...
