3600 Stall TC with 3.15 gears
There has been some discussion previously on this board as to how a high stall TC would work with 3.15 gears. I would like to present the results of my setup. My car was a 99 with the standard boltons: Kooks headers with x-pipe, Vararam, LS6 intake and dyno tuning. In that configuration my best 1/4 mile ET was 12.63 @110.47 with a 1.95 60 foot time. Recently I added a 3600 stall Vigilante TC and a custom ground cam by the Vette Doctors. Around town the car drives great. Yesterday was my first trip to the track. I ran a new best of 11.85 @ 114.16 with a 1.68 60 foot. In another run I had a 1.65 60 foot. The car launches great and pulls really hard. Weather conditions at the track were similar for both the old setup and the current setup. So what I am trying to say is that a high stall TC can work well with the 3.15 gears. Thanks to Carmen, Dennis and Joey at the Vette Doctors for giving me a great running ride.
Former Vendor
Dave
See you in two weeks. Give me a call this week if you got time.
Originally Posted by EB20003
Nice. Getting 60's like that have you considered the DTE or some other brace? I'd be deathly afraid of busting something with 60's like that.
As for a high stall and 3.15's, I agree they do work fine. It'll just feel a little loose. I had a SY3500 and 3.15's, I swapped out the 3.15's for 3.73's and saw hardly any gain at the track. The car just felt more responsive.
but who here ever said that wasn't the case???
Anyways... congrats on a mod that gave desired results.
Originally Posted by TheVetteDoctors
Its all in the tune
Bob
Originally Posted by Eric Fischer
Many people still feel that a performance converter MUST be matched with hi ratio gears, like 3.73's or greater. You'll see it all the time on this forum -- comments like "don't waste your time with a converter and stock 3.15 gears" or "since you are already have the rear out, you might as well put in gears too...". Dave is just providing some data that indicates the contrary.
Originally Posted by Mitch C
A 3600 stall with 3.73 gears is going to feel alot tighter than if you have 2.73 or 3.15 gears.
For this reason alone, I recommend gears. My YPT4400/4.10 combo feels tigher than my SY3500/3.15 did.
Dave, thanks for the post, impressive results.
I have a 98 rag top with almost anidentical bolt-ons and same tranny/gears.
Are you still running the stock heads with the new cam and converter?
Also, I`m just curious what type of tires you run at the track, I`ve been thinking of trying a set up similar to yours and was curious if the tires are part of your impressive formula.
Cheers, Rick
Cheers, Rick
for those that are at the track a lot, a high stall TC can work miracles.
Originally Posted by R.P.
Dave, Are you still running the stock heads with the new cam and converter? Also, I`m just curious what type of tires you run at the track, I`ve been thinking of trying a set up similar to yours and was curious if the tires are part of your impressive formula.
Cheers, Rick
Cheers, Rick
He is running stock heads but with the appropriate spring package. And yes he is running 18" BFG drag radials (295/35/18)
