New Heads; All Pro; 330 cfm out of the box.
NCM, WSCC & SCC Member
Interesting. It says like $1750 on the PDF price list from the main page.
I'm not positive, but I think that might just be for the bare castings, which would mean you need valves, springs and hardware.
They look like a good alternative to the others...
Steve
Steve
Originally Posted by wantac6
I was told buy them at PRI that the head would flow 290-300 out of the box.It will flow more with porting.
Originally Posted by CNB
They better flow 290-300 with a 230cc intake runner.
I have the flow sheets from Bob. They flow around 290 out of the box, they need to be finished. I think Cartek is the only one that's used then at this time. They are putting them on their bigger engines 427ci+.
Things that make you go Hmm.
Good thickness
Room for 2.15/1.625 valves
Changed plug angle
Room for roller rockers
Room for big porting
Hmm. Derserves watching, imo.
Changed plug angle
Originally Posted by #001 2001 Z06
We also have a revised set from All Pro last friday. tt intake valve 2.200/ ss exhaust 1.625, revised spark plug locations, and the rockers offset .250. These will go on C5R-454 cu. in. motor after extreme porting and we will put on the flow bench. I also have a set of C5R heads (tt intake valve 2.250) already done, but the All Pro heads sound interesting so compare the two. I will post the result as soon as we done with the test.
TNT,
Sounds like a mean motor.
Be interesting to see the data and comparision.
#001 2001 Z06
I now feel like the small guy in the locker room with my little 430 cid motor.
#001 2001 Z06
Platinum Supporting Vendor
The problem I see with these heads is a poor combustion chamber shape. It looks like a standard LS1 or 6 liter head. A better shape with more quench area would be better.
There have been discussions about changing the chamber. The port is good, though. I'm hoping they'll change the chamber.
__________________
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
A&A CORVETTE
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
A&A CORVETTE
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
I know some of the tuners out there are testing them: W2W, Cartek etc.. but they are the testing batch heads. All Pro since then they revised the heads and i got the latest set from them. I compare to my C5R heads and they are many similarities. Also, they have 1/4 thickness all the way around for extreme porting. Again, i can't coment until i have the result, anh from the knowledge i think these heads should bring exel results. C5r heads are more then great, but a lot expensive then stock set up.
#001,
The size does not make it go fast, the combinations that what i want to achieve.
#001,
