Inch Vs foot lbs. conversion factor?
I believe lug nut s are torgued to 100 ft bs, is there a conversion for inch pounds? How many inch pounds would equal 100 foot pounds?
Originally Posted by marco383
I hope that you don't plan on torqueing the lug nuts with an inch pound calibrated torque wrench.
do they go to 1200 in lb ?
Originally Posted by Hall1836
Thanks for the responses, had a brain f*** re inch pounds, and no I'm not using inch lbs to do foot lb work. Thanks again.
At first I was thinking maybe you grew up in Europe or something.
