Will 02 Z06 exhaust manifolds bolt up to 2000 FRC?
Depends. 2000 was a transitional year for the C5. Earlier versions still had the longer stainless steel manifolds from 99 with the passenger side air tube over the #7 exhaust port. Mid year or so they switched to shorter cast iron manifolds but the air tube was in the same place. It has sind been move to the #5 exhaust port. Bottom line is that you will probably have to change the H pipe assembly to an 01 and up and definatly have to change or extend the passenger side air tube. Is is worth it? Up to you pal. - C.
