Is lowering the C5 on stock bolts worth it? Can you see the difference?
Old 05-02-2005, 02:38 PM
HotLaperC5
HotLaperC5's Avatar
Default Is lowering the C5 on stock bolts worth it? Can you see the difference?
I want to lower my C5 Coupe in the front and back but I've heard that lowering on the factory bolts alone doesn't make that much difference in appearance!? Is this True!? Anyone with pics of lowering on factory bolts please post.
Oh yeah, any drivability issues afterwards (especially the front)!!?
Thanks guys!!
Old 05-02-2005, 02:51 PM
ericdwong
ericdwong's Avatar
Thanks guys!!
I lowered mine on the OE bolts and definately noticed the front end being lower.
If you're careful you shouldnt beach the car too badly. I drive my car every day. I do hit the flexible spoiler on the bottom but otherwise no big issues.
5 Liter Eater
5 Liter Eater's Avatar
St. Jude Donor '11
You can TOTALLY see the difference. As far as feel, it does feel quite a bit "sportier". Not harsh but not soft like before. I installed Bilstein Sports at the same time so I can't say if the increased stiffness is because of the shocks or the lowering. I don't seem to scrape on things that I didn't prior to lowering (if that makes sense), but I may just be being more careful.
I dropped ~1" in front and 1.25" in back (with the Z51 suspension)
I really regret not lowering on stock bolts a long time ago! DO IT!
Old 05-02-2005, 03:00 PM
Swany00
Swany00's Avatar
It made a huge difference for me. I lowered the front end a couple weeks ago, but it had too much of a rake and lowered the rear this weekend.
It rides a bit stiffer, holds turns far better and doesn't look like a 4 wheeler anymore. I'm really happy with how mine turned out, it was just enough to make the new wheels and tires that are coming in this week look a lot better.
Lower it with the stock bolts and feel it out, if you want to go lower you can always cut the bushings after the fact.
Old 05-02-2005, 03:02 PM
Rob P
Rob P's Avatar
The car looks much much sportier on lowered bolts. I have T1 springs and the bolts lowered to the max and I don't have any issues other than the front rubber spoiler rubbing when I go up or down steep driveways.
I don't believe lowering the bolts will give you any difference in ride quality but the car should handle better because you are lowering the center of gravity.
Try lowering it 3/4 of the way down and drive it for a while and if you need more you can always lower it further or raise it if you do not like it. It isn't a big job.
You won't regret it.
Old 05-02-2005, 03:17 PM
WKMCD
WKMCD's Avatar
People look at my vette and can't figure out why it looks so much better. 18's all around with Bilteins and lowered as above. Handles great and looks
Old 05-02-2005, 03:18 PM
NassyVette
NassyVette's Avatar
That's lowered on stock bolts...just right
Old 05-02-2005, 03:22 PM
lost
lost's Avatar
Without adding an appropiate shock, it is strictly for looks, you will hit the bump stops which if you drive agressively can be dangerous to your health, not to mention the structural well being of your C5.In simple terms every fraction you lower the car you have that much less travel in your shocks. At stock heights, stock shocks whether they be standard, Z51 or magnetic ride only have a limited amount of travel.If you like to push the car through the twisties,hitting a bumpstop at a corner apex can spell disaster.If I see a sign that says dangerous curve 35mph, I immediately see if I can take it at 70mph. At my age its one of the few thrills I have left...
Old 05-02-2005, 03:25 PM
terpesman
terpesman's Avatar
This pic is great. I like the wheel/tire combo. Very, very
Old 05-02-2005, 05:33 PM
NassyVette
NassyVette's Avatar
Old 05-02-2005, 05:45 PM
BlackSheepZ06
BlackSheepZ06's Avatar
Looking good Adam!!!
Old 05-02-2005, 06:26 PM
jrose7004
jrose7004's Avatar
Received 1,673 Likes on 1,296 Posts
Make sure you get an alignment after lowering or you'll ruin your tires. Wait until the car has settled 100 miles or so!
Old 05-02-2005, 10:03 PM
ROMA 75
ROMA 75's Avatar
This is b4:
And this is After:.....
Old 05-02-2005, 10:59 PM
MY1STPEWTER
MY1STPEWTER's Avatar
I lowered mine on stock bolt's and love the new look. Also, I can't tell any difference in ride quality. Do it, you won't be sorry.
Old 05-03-2005, 01:30 AM
VetteNoob
VetteNoob's Avatar
F45 lowered on stock bolts. Here is a pic of it sitting next to a NSX in the grass.
Old 05-03-2005, 08:54 AM
gunnygotavet
gunnygotavet's Avatar
Default what about taking the stock bolts out
I was told you could take the stock bolts completely out and its the lowest it can be. Has anyone done that??
Old 05-03-2005, 11:33 AM
Toque
Toque's Avatar
Location: Wylie TX --> Less is More, except under the hood !
This is not a paintshop ! Can you say 4x4 !!!!
My 2004 Z06 Stock, then lowered the max on the stock bolts.
Do you think it looks better ?
Toque
To Is lowering the C5 on stock bolts worth it? Can you see the difference?
Old 05-03-2005, 12:07 PM
0EG@EnglandGreen
Supporting Tuner
Support Corvetteforum!
EG@EnglandGreen's Avatar
Location: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Slam it (see sig)
Old 05-03-2005, 01:27 PM
RCordier
1st Gear
RCordier's Avatar
Default Lowering the suspension
My 1997 C5's rear ride hight is about 3" between the top of the tire and the wheel well opening. I'm very interested in lowering the opening to about 1". The 1st picture of the yellow convertible is close to the height of the rear of my car. Everyone mentioned lowering by adjusting the OE bolts(?). Where are these? I replaced the rear rotors and brake pads last weekend and noticed that the is a bolt on the lower A-Arm that had hash marks on it. Is this the bolt being referred to? If not, which one(s) are they?
Old 05-03-2005, 02:11 PM
IDntSpd
IDntSpd's Avatar
Default 97 lowered using stock bolts worked great
I replaced my springs and it raised my car to where i didn't like it so i lowered it using stock bolts worked great. I wouldn't want to lower it any more then what it is.
Quick Reply: Is lowering the C5 on stock bolts worth it? Can you see the difference?
