running 17's all around on my 03?
Is it safe to put some 17" rims on the back of my '03 for the strip. I have some good tires but they are on 17" rims. Thanks for the input.
It'll be fine. Using 17's will allow you more sidewall with the same diameter tire, will launch better for the dragstrip.
For a road course it'll work fine also. 275/40-17's on front and 315/35-17's on the rear, or 315's all the way around. Wider contact patch, lower center of gravity than stock.
Don't forget about active handling. It expects a speed difference
between front and rear because of different diameters. If you
select different sizes to take this into account I would think
it would be fine.
it would be fine.
Originally Posted by 6Speeder
It'll be fine. Using 17's will allow you more sidewall with the same diameter tire, and 315/35-17's on the rear, or 315's all the way around. Wider contact patch, lower center of gravity than stock.
