passenger side window problem
4th Gear
MY window on the passenger side quit working.I pulled the panel off and checked the control module.When I touch the window down switch I can here the relay kick in,but the window will not go down.
I put a meter on the two prongs at the window motor and it read .8
ohms resistance.Not sure if this is good or bad? I tried hooking a 9volt
power supply to the window motor,to see if I could get the window to
move at all,No Luck..Anyone have problems with their powerwindows?
Any good tech. articles on how to work on these windows, and how
to trouble shoot? This problem is with my 99 c5 conv.
I too would like some input on this! I have not checked anything on my as you seem to have.
But, my Passanger side widow is the same, on a 2000 FRC. It worked one night when I had to roll it down to talk to a LEO, then about two days later I tried it, and NADA! At night with lights on you can see the lights dim, AKA on the arm rest switch, trying it from either side. But, the window does not move.
HELP US PLEASE! As I know the cost at a dealer will be way more than it worth!!
God Speed! Doc....
God Speed! Doc....
"AlohaC5" Senior Member
This is a known mechanical problem on the C5. My passenger side window module failed on my 2004 C5 with only a few miles on it. Covered by warranty. If you're out of warranty - the dealership may still cover it because its a known problem affecting all years. Do a search on the forum and you will find many members that experienced the same problem. Good luck!
window
Here's a thread with some info.
http://forums.corvetteforum.com/show...835&forum_id=1
My assembly from Fred Beans was about $185.
I've fixed mine (99FRC) 3-4 times by doing this: remove door panel and locate the motor, w/ ignition on, hold down the window down button and beat on the motor w/ hammer, vice grips, etc. My car has worked perfect for the last year w/ this fix. Probably does the same same thing as beating on the door panel above the speaker and slamming the door but just goes directly to the spot needing attention (the stuck motor) Good luck.
Pass Window not working
Yep, I have the same problem, can hear the clicking, window won't go down. Took it to the dealer, of course it worked then. Stopped working one more time, works now. Seems to not work after the car gets rained on, maybe moisture is the problem? Guess the only fix is to replace the window motor, eventually. It's a 2001 MN6 Z51 coupe.
The quickest potential fix is to hold the window switch in the down position and slam the door closed hard a few times. This usually frees up the motor and gets things working again. If that doesn't work you are usually looking at needing a new window regulator.
window repair
The regulator is bound in the up position, in my case on my 99, the up stops were not set, allowed the window to go too far up. Remove the regulator, take the motor apart so you can turn it to relieve the bind and adjust the window. The motor has a thermal lock out and gets power but can't move, try and find my thread as my memory XXX.
Common problem. Had both of mine do this last year. Seems to happen when windows are not used much. Unstuck mine by driving over a rough road and depressing window switch. The door slamming routine didn't work for me. I try to open and close them occasionally and have had no further problems.
Originally Posted by curtbriggs
The Search on this forum leaves allot to be desired, I wrote a thread on repairing electric windows and I couldn't find it and I know the title and date.
I have never gotten it unstuck by slamming the door. I remove the panel, speaker, then remove the nuts holding the motor assembly to the door. Then I reach through the speaker hole and remove the bolts holding the motor itself on the assembly. I pull the motor back about 1/8" and hit the button and twist the motor clockwise and counter-clockwise and shortly the window will start down. Don't pull the motor back too far, the brushes will fall out and it a pain to get them back in without removing the regulator. Then I just put it all back together. I never remove the windows or regulator from the door.
Be very careful working in these doors! That auto-down feature of the power windows makes it easy to get you hand and fingers caught in the door. These window motors can hurt you really bad!
I thought the thread below was pretty interesting. Hopefully it's useful here.
Electric windows, how to repair
Great tip!! My drivers side power window motor of my C5 Vert stopped working today.. Found this thread using the search function!!
Slammed the door and after the first time, the motor started working again!!
